Syldrin's Alphabet. 56K GL
Old 06-27-2012, 01:18 PM
Syldrin's Avatar
How it sits right now. It has an oil leak I have to fix on the instatap on my pan wasted all my good Motul.
Sent from my ADR6425LVW using Tapatalk 2
Syldrin is offline
Old 06-27-2012, 01:34 PM
Roller_Toaster's Avatar
Did you get angry at your laptop and shoot it?!?
Roller_Toaster is offline
Old 06-27-2012, 02:39 PM
Syldrin's Avatar
Why would I get angry at my laptop?
Syldrin is offline
Old 06-27-2012, 02:40 PM
Syldrin's Avatar
Ohhhhh the background on it. That is just my wallpaper its pedobear breaking through the screen.
Syldrin is offline
Old 06-28-2012, 01:53 PM
Syldrin's Avatar
It's running just drove her to work. She is running rich I'm using a 500cc map on it at 13lbs (i got scared and backed out of the throttle) the afr's were 10ish. I thought I had set the spring for 11.6 psi but apparently I put the wrong ones in. Tial doesn't make it easy to sell the difference in their colors.
Syldrin is offline
Old 06-29-2012, 06:55 PM
sebbyxtc's Avatar
what did u use to cut ur crashbar?
sebbyxtc is offline
Old 06-29-2012, 07:44 PM
Syldrin's Avatar
A sawzall with a metal blade on it. I ended up having to remove it the ic is too big.
Syldrin is offline
Old 06-30-2012, 05:54 PM
tC_Crisis's Avatar
Pictures of finished product, kind sir
tC_Crisis is offline
Old 06-30-2012, 08:34 PM
Syldrin's Avatar
tune date is tuesday at 2pm.
Syldrin is offline
Old 07-01-2012, 01:22 AM
GUNNIST14's Avatar
This makes me want to reboost again. The manifold is a work of art. Well done sir. Looking forward to seeing your numbers.
GUNNIST14 is offline
Old 07-01-2012, 05:44 PM
Syldrin's Avatar
so i was cruising around on the highway and it was 82 degrees outside and believe it or not my IAT's were shockingly only 76 degrees. this intercooler is super efficient. with the MAF sensor being right below the TB that is about as accurate as it will get on the IAT.
Syldrin is offline
Old 07-02-2012, 12:51 AM
crush02342002's Avatar
pipe was prolly cold or somethings up with the sensor. you using meth?
crush02342002 is offline
Old 07-02-2012, 04:46 PM
Music City Scions
rhythmnsmoke's Avatar
Finished pic with bumper on?
rhythmnsmoke is offline
Old 07-02-2012, 05:33 PM
Syldrin's Avatar
nope just a really efficient ic Chris. My IAT's are always below ambient as long as i am moving. if i am staying still they will jump up to around 100 degrees.
Syldrin is offline
Old 07-02-2012, 05:34 PM
Syldrin's Avatar
i am in the process of making brackets for the ic trav to fix my gangster lean my ic has. if you jump on my fb there are a few photos if you want to see it.
Syldrin is offline
Old 07-02-2012, 07:42 PM
Syldrin's Avatar
I punctured my radiator being careless when I installed my slim fans so I'm going to go pick one up in Anaheim.
Syldrin is offline
Old 07-05-2012, 03:56 PM
Scionetics
KAD
paul_dezod's Avatar
Take your time grasshoppa
paul_dezod is offline
Old 07-05-2012, 05:32 PM
Syldrin's Avatar
Working on it now. With some luck maybe Shaun can get me in today.
Syldrin is offline
Old 07-05-2012, 07:39 PM
Scionetics
KAD
paul_dezod's Avatar
Do it!
Old 07-06-2012, 12:54 AM
deez's Avatar
<-- Watching
deez is offline
Quick Reply: Syldrin's Alphabet. 56K GL
