Synapse Engineering BOV Testing Day
Old 06-24-2008, 01:43 AM
  #101
PrestigeRacing's Avatar
Comes with it. It's removable though.
PrestigeRacing is offline
Old 06-28-2008, 04:07 AM
  #102
deathbyc4's Avatar
If you order the bov with the adaptor plate for the hks, per Prestige is does not comes with the c-ring and o-ring. Can be a problem for some if you want to sell the hks.
Until then, you can buy the c ring/ o ring from http://shop.edoperformance.com
deathbyc4 is offline
Old 06-28-2008, 04:40 AM
  #103
That is correct. The synapse BOV does not come with a C ring. You will need to keep the existing C ring from your HKS BOV. We do carry HKS C-rings, however they have not been added to the website yet.
Old 06-28-2008, 05:09 AM
  #104
Mr_Meaty's Avatar
yeah...i noticed there was not an option to order it with the HKS adapter AND the anti-lag...
Mr_Meaty is offline
Old 06-28-2008, 01:19 PM
  #105
Rydrdg's Avatar
alright, I just got my Synapse bov im gonna swapp it off with my greddy rs bov. my car was experiencing prblem just like brown dogg.
Rydrdg is offline
Old 06-28-2008, 04:52 PM
  #106
Rydrdg's Avatar
install it today but my car keep on stalling an shutoff . I dont know what happen, so i put my greddy rs bov back on and recirculate it an runs fine. someone know hoe to work this?
Rydrdg is offline
Old 06-28-2008, 05:07 PM
  #107
If your synapse BOV is venting to the atmosphere, you need the anti-stall kit. If you're recirculating, you might want to check what ports you're using on the BOV.
Old 06-28-2008, 05:17 PM
  #108
Rydrdg's Avatar
I am using ports A and B, I guess I need a anti stall kit , I tried looking at your website but you can not purchase it individually. One other thing does it need to be tap as close as possible to intake manifold vac line, becuase my wastegate actuator is tap already to vac line.
Rydrdg is offline
Old 06-28-2008, 05:32 PM
  #109
We're going to add the Anti-Stall kit as a separate option today.
in your case, since the Greddy RS was recirculating, your car would run much better recirculating the BOV. The only reason we didnt' recirc browndogg's tC was because the dezod kit isn't made to do so.
Old 06-28-2008, 06:29 PM
  #110
Mr_Meaty's Avatar
wow...your greddy RS was already being recirced and it was having those issues?
Mr_Meaty is offline
Old 06-29-2008, 10:31 PM
  #111
deathbyc4's Avatar
got mine on, havent hooked up the third barb yet, gotta find a fitting for the compressor. still flutter dumps but not as much as the hks. sounds like puff, puff, whooooosh. it's quieter too. i wont be able to do a before dyno just an after, which will be soon.
Old 06-30-2008, 03:36 AM
  #112
yamaha16bw's Avatar
Hook up the port 3 to the wastegate line and that fluttler will go away. It make the BOV open insanley fast.
yamaha16bw is offline
Old 06-30-2008, 07:18 AM
  #113
deathbyc4's Avatar
i plan on it once i get the fitting.
Old 06-30-2008, 07:23 AM
  #114
BrownDogg's Avatar
So on my car... port 3 inst being used right now. And I have the Tial wastegate and one of the ports on it is just open to the atmosphere. So if I hook up the empty port on my bov and the empty port on my wastegate.... that will work?
Do you have a pic of your car and bov and wastegate doing this for reference? That would be awesome!
BrownDogg is offline
Old 06-30-2008, 12:42 PM
  #115
yamaha16bw's Avatar
No. The line running to the bottom of your wastegate should be the boost signal line from the compressor of the turbo. "T" that and run that same sidnal to the port 3 and the BOV will work sooooo much better.
Old 06-30-2008, 12:57 PM
  #116
tcengel's Avatar
Installed mine on my turbonetics kit last night. Seems to work great, no more stalling and most important, no more backfires! Those huge backfires were going to get me pulled over eventually. I would say it's a great improvement for a small investment.
tcengel is offline
Old 07-01-2008, 04:18 AM
  #117
BrownDogg's Avatar
Is that safe to do?
Old 07-01-2008, 05:09 AM
  #118
deathbyc4's Avatar
port 1 and 2 are on the back of the unit and 3 is on the side. it is designed to have the boost on that side port.
Old 07-01-2008, 01:04 PM
  #119
yamaha16bw's Avatar
Is that safe to do?
Its how its made to work. If you check out there youtube videos mine sounds just like the wrx test car.
Old 07-01-2008, 02:21 PM
  #120
Schuller's Avatar
Is that safe to do?
I was wondering if you tried hooking up the second unused port on your old Raptor to the boost line near the compressor. IF you tried that back when you had your old Tnetics setup did it help with compressor surge?
Schuller is offline
Quick Reply: Synapse Engineering BOV Testing Day
