Synapse Engineering BOV Testing Day
Old 08-07-2008, 07:47 AM
  #141
deathbyc4's Avatar
its best to have both rear ports to vacuum signal and the side port c connected right it the compressor if you have a hole there, otherwise make one.
deathbyc4 is offline
Old 08-07-2008, 11:32 PM
  #142
deathbyc4's Avatar
aight, got the BOV tapped to 10-24 and some set screws, its not coming off anymore. easy fix for the mechanically inclined.
Old 08-07-2008, 11:39 PM
  #143
Rydrdg's Avatar
I would use washer on both side of bolt screw it should prevent it from unscrewing during any kind of movement. I recirc mine an running strong like a champ, last night I smoke a rsx type s 4 times an he still dont know what the hell happen.
Rydrdg is offline
Old 08-08-2008, 01:46 AM
  #144
deathbyc4's Avatar
it the screws that hold the flange adaptor to the bov that were the problem.
Old 08-13-2008, 01:34 PM
  #145
kirk212's Avatar
I finally got my Synapse bov installed. This things kicks major ___. ____es all over the tnetics raptor bov, which by the way really sucks. In a way I kind of miss the loud annoying sound of the raptor, only because this thing is so quiet. It sounds like an STi's bov. Either way, its a great product so far.
kirk212 is offline
Old 11-10-2008, 01:35 PM
  #146
tcengel's Avatar
Originally Posted by deathbyc4
yep, my bov popped off today, where the set screws hold it to the adaptor. i lost one of the set screws and hopefully i can keep it from popping off until tomorrow. i doubt i can find another set screw so im going to fab up a bracket to hold the bov to the pipe. i big charge pipe clamp and rubber should do the trick.
Yeah, I lost one of my screws too. Anyone know what size they are so I can buy a replacement of some sort?
tcengel is offline
Old 11-10-2008, 02:39 PM
  #147
deathbyc4's Avatar
go buy a 10-32 tap and two 10-32 set screws from a hardware store (ace hardware or something similar) and then tap the holes larger to get a better grip on the unit. make sure to add in some locktite, blue works fine.
Miqmiqmiq
04-16-2016 02:34 AM
cessblood
09-15-2015 06:50 AM
NonStopTuning
01-20-2015 05:20 AM
Ramroids55
01-16-2015 02:42 PM
Besk_one
10
12-06-2003 06:45 PM
Quick Reply: Synapse Engineering BOV Testing Day
