synapse wastegate question
i have the dezod s1 turbo kit with the synapse wastegate. i bought the kit used off of someone here on SL but he did not include the instructions for the wastegate. i was wondering if anyone on the forum has used this wastegate and would be able too provide me the install manual or guide me through the install. thanks
nate
nate
depending on the high pressure side depends on where you need to plug in the vacuum line. if the bottom of the wastegate ( the one with the valve visible) is the high pressure side, then the vacuum line goes to the port cloest to the valve ( on the base of the shiny part close to the valve part). otherwise, you use the top port.
http://videos.streetfire.net/video/5...86003c41aa.htm
Well the WG has 4 ports and you can use 1 for 5PSI, one for 7 PSI, one for 10 or something like that.
Go to here:
http://www.synapseengineering.com/
Hit archives and then DL the manual for the WG
Go to here:
thanks for the replies guys. now i ran into anohter problem . i am using the the blitz dual-sbc spec s boost controller. it is telling me too connect the sloenoid fromt he controoler too the top of the wastegate and then the bottom port of the wastegate too the turbo.
now the wastegate tells me too connect port C&D too the boost source and nothing too the trubo im really confused.
some one please help me
thanks
nate
thanks
nate
heres anohter noob question and hopefully somone can answer it . my boost guage tells me too connect the in side too a pressure port from before the throttle body. would that be the same as connecting it too the vacuum source?
Strictly Scionized
I have no clue what comes with that kit . it came with a synapse wast right? Then it mit have came with the bov I want to now what it sounds like on a tc. is that a good answer for u resu.
