tC intake manifold in the works
Old 11-30-2007, 01:48 AM
Music City Scions
AllianceAutoSports's Avatar
Default tC intake manifold in the works
Now that I have the fuel rails done, I have started on an intake manifold. This one is for a friend, but I plan on making some more after this one is finished. Here are some progress pictures.
AllianceAutoSports is offline
Old 11-30-2007, 01:50 AM
Scott8's Avatar
NICE!!!!
Can you install this without pulling the motor???
Scott8 is offline
Old 11-30-2007, 01:56 AM
Prophecy2k4's Avatar
I second that question.^^
Prophecy2k4 is offline
Old 11-30-2007, 02:06 AM
Music City Scions
Yes you will be able to install this without pulling the motor. The stock intake can be pulled without pulling the motor, and this one was built around the stock intakes dimensions.
Old 11-30-2007, 02:15 AM
MrBurrito's Avatar
now the question is will it go into production if so how much?
MrBurrito is offline
Old 11-30-2007, 02:26 AM
Mightygnu's Avatar
No, the question is how beneficial will it be?
Mightygnu is offline
Old 11-30-2007, 02:27 AM
Scott8's Avatar
X2
Scott8 is offline
Old 11-30-2007, 02:28 AM
MrBurrito's Avatar
oh yeah that too and hey are u going to the oc meet this sunday?
Old 11-30-2007, 02:31 AM
Mightygnu's Avatar
Not to threadjack, but yes I will be there on sunday.
Old 11-30-2007, 02:32 AM
Scott8's Avatar
if you have a highly boosted tC, or a crazy NA high compression motor, this would help considering our intake mani is plastic
Scott8 is offline
Old 11-30-2007, 02:34 AM
Mightygnu's Avatar
I knew that, but wanted some factual evidence from the manufacturer.
Music City Scions
I do plan on a production run of these, now as far as how much, I really can't say just yet. And as far as the benefits, I guess the biggest benefit for the boosted tC's would be an intake that will stay together. I will talk to my buddy about the before and after Dyno numbers to see what or if anything has changed from the previous dyno run. This intake is still in the works, so bare with me on the finished product. Thanks for the interest!
Old 11-30-2007, 02:36 AM
Mightygnu's Avatar
you have pm!
Old 11-30-2007, 02:46 AM
Enrique9876's Avatar
you refuse to disappoint us and i like it!!!!
what are you planning dollars and cents wise... looks like ill be buying the fuel rail AND the manifold at the same time......... darn my fundage is going to suffer because of you hahah
Enrique9876 is offline
Old 11-30-2007, 02:53 AM
Music City Scions
At this point I can't really begin to say any amount. Most of the items I used were bought, used from something else, or hand made on a manual machine by me. The production runs will be all manufactured in-house on CNC machines and some of the items will have small mods done to make assembly easier with less welds. When I get this one done and let our machine shop quote some of the parts I will have a good idea of what it will cost.
Old 11-30-2007, 02:54 AM
perfect answer. thanks
Old 11-30-2007, 06:56 AM
kungpaosamuraiii's Avatar
So where does the throttle body go? I only see the drum and four runners...
kungpaosamuraiii is offline
Old 11-30-2007, 07:11 AM
thats all he has done SO FAR
Old 11-30-2007, 01:32 PM
Music City Scions
I just posted a picture of what I got done yesterday, here is a picture of the TB flange. Sorry for the crappy picture, and yes it still has to be tapped. Most of the intakes I've seen only have the one big hole and the bolt pattern. I'm making this one like the stock TB flange so nothing is affected by it. And it will allow for all the components to be in their stock locations. And as I said before I have plans to change a couple of things on the production run. One being the intake tube. The intake tube on this one will be coming in the lower back side in the center. The production one will be a little different, not much but still different. And again bare with me as this is only in its beginning stage, I am making welding jiggs and patterns as I make this one, so it may still be a little while before they are available.
Stock
Aluminum
Old 11-30-2007, 01:46 PM
Scott8's Avatar
looking good so far!
Scott8 is offline
Quick Reply: tC intake manifold in the works
