tc not allowing boost?!?!?!
can someone help me. i just turboed my car. i have a top mount with turbonetics evolution waste gate.with 9psi spring. its a brand new t3/t4 ebay turbo. 50 trim. greddy type rz BOV. 440cc injectors. and 1 step colder irdium plugs. my gap spec is at .32 im having a problem going into full boost aka just going into full throttle period. everytime i try to hit the gas it acts as if it is detinating. u can hear it building boost then it just wont allow me to go full throttle. half throttle i have no problems. i wish i could describe the noise it is making. can someone help me. i have a threadstone vaccum block that i have my boost gauge, and BOV i tapped them into the brake booster.the waste gate hooked into my throttle body. please someone help so i can get this thing tuned. i have a greddy ultimate installed but i cant tune it cuz of this one problem. i brought it to get tuned but he said he couldnt help me because my car was acting like this.
if its not a boost leak, than im more than likely sure that its due to the fact that ur not tuned. the factory ecu will not like that amount of boost pressure at all. thats way too much boost for the ecu to try and compensate for. imho id say try and find someone to send u a map for a similar setup and see if that helps. i had my car on stock ecu and injectors w a 4psi spring and that worked fine, i threw my mbc in just to set it and had it set at 10 psi and the car just fell on its face and the car leaned out like crazy. it couldnt provide sufficient fuel to compensate for the boost. im not sayin this is the case, but it may be a possibility.
well if ur not tuned like ^ mentioned then there is ur issue right there...u will b running terribly lean n u WILL blow ur motor i due time how much time idk but sooner rather than later if u keep running ur car like this my advice to u would be go and get tuned n everything should be good well good luck n happy boostin keep us updated
ok i got tuned
i got tuned and it still did it but after a second it would launch. so i took it back the next day and we did a street tune. he kept changing things up and now its all good. spinning tires all day. i am having one problem though. im at 277whp. he said at 5 grand my fuel pump cuts out. that would be because i need a better one. mine is stock lol after i get the fuel pump and retune i should be at 300 wheel. pretty good if u ask me anyone got a walbro 255?
On pump gas unless you have some retarded big injectors, youll run out of fuel by 300whp. Only reason you might get a tad more on very large inj (1000cc+) is b/c they'd still be able to flow a decent amount when fuel press drops to 30 psi or so on the stock pump.
crimson_sinn
09-25-2015 09:41 PM
Subaru86
Scion FR-S ICE & Interior
09-10-2015 08:11 AM
umnitza
08-21-2015 12:35 AM
