tC Turbo Project
Originally Posted by ERIC-TC
Check out the upper radiator hose connection -It's gone! OMG, how are you getting water into the block? I see a AN type fitting in it's place - but it looks too small, it's easily a third the size of the stock radiator hose. Who ever custom made this turbo has some big brass "@#@$"! I hope it works good.
Originally Posted by mike6789k
what does your engine temp sensor say?
Why do you continue to crap on e-manage? Check all the setting/jumpers on the e-manage board, double check all harness connections. It really is not rocket science...just like hooking up a stereo.
Idle is not under e-manage control. The ECU will call the shots in closed-loop mode. If idle is off then check for air-leaks. What maps are you using on the e-manage right now?
unless you can tell me what is wrong, or i'm just had bad luck with defect emanager?
Will checking with tunner tomorrow for the Greedy mapping, unless you have different mapping from Greedy?
i see you have the emanager too, do you do anything else to it? let me know what you have change beside factory setting.
Originally Posted by calvinwch
almost pick up my car today, flip Greedy mapping sux. need to re-tuned it again. Car can't idle good will shut the engine off.
any one has the same problem with Greedy emanager?
boy here we go, so there is other people having same problem while car is in idle.
Fracking Greedy .
I sue will see what happen today and share it to everyone.
If anyone here has fix the idle problem please share it, so it will take less time for my shop to find out the problem.
I don't think the idle issue is directly related to e-manage. You've got a custom turbo. The shop that is doing the work should know what they are doing. Idle issues are typically related to fouled plugs, small air-leaks etc. 15-16:1 A/F at idle is not bad and in no way is it rich. Actually it's real close to normal which is 14.7-15.3 .
What's your main injector correction set at on your e-manage? What maps are you using? When are you making fuel corrections?What size injectors are you running?
What CEL codes are you getting from the tC ECU?
I'm not saying that it's impossible the idle issue is caused by the piggy-back...but it's unlikely that the piggy-back is the cause of your problems. Lots of folks here are running with Greddy e-manage both blue and ultimate and idle problems do not appear to be a recurring issue.
Got off the e-manage is BAD bandwagon and do read the programmer software manuals. They are availble for download free at www.greddy.com
Fracking Greddy .
almost pick up my car today, flip Greddy mapping sux. need to re-tuned it again. Car can't idle good will shut the engine off.
any one has the same problem with Greddy emanager?
Fracking Greddy .
let me know which i can tell my shop make sure that the setting are match.
Guys it is finished, it work good now.
I need some sleep now, just got home with fresh burn smell.
make little thing change, and we got it to work.
was the sensor for the airflow little to close to the turbo, we re-route the pipe
will post pic tomorrow,
Update, car run great, boost great. But i got defect turbo(oil leaking), which need send it back for warranty.
can't give anymore pic for that, will take more pic when i receiving the turbo back.
what a luck.....
stay tune, i'll be right back.
what a luck.....
Originally Posted by toyotaracer9
looks very nice and neat . what kind of power are u lookin for ? I dont know how true it is but I hear the MAF sensor give unstable readings that close to the impeller .
I didnt want to keep nagging u about this , but I figured this was going to be an issue . glad u got it lined out .
Originally Posted by MysTiKchRis
So it wasn’t the Emanage?
