tC Turbo Project
#41
looks very nice and neat . what kind of power are u lookin for ? I dont know how true it is but I hear the MAF sensor give unstable readings that close to the impeller .
I didnt want to keep nagging u about this , but I figured this was going to be an issue . glad u got it lined out .
anyway, after all this fix. The D A M N turbo went bad, start spit oil after i drive the car home and test run on the 2nd day.
It just my bad luck of the day, need to wait the replacement turbo now........
can't have fun for the hoilday now.....
#42
Originally Posted by calvinwch
Originally Posted by zer0
What year car?
#43
do u have a restrictor in the inlet oil line ? 60-80 thousandths for a journal bearing and 35 thousandths for BB turbo . the trubo may not be bad , u may just need a restrictor , the seals will stop leaking if this is the problem .
#44
#47
Originally Posted by IAmTheProdigy
What size injectors are you running?
#48
I didn't even crank up the boost, i set it for running at 7lbs. it is around 300 already as what we estimate, will see what happen when i have time to have it on dyno.
i'm not running the turbo kit greddy have, i'm using different turbo and different header with downpipe all the way 3"
it is not just the injectors will make the power, if you tune it right with the parts. It can run.
before anything happen, i won't say i'm 100% sure but should be around there at 300 for 7lbs boost.
#52
Originally Posted by ERIC-TC
Injector Duty Cycle -This is a measutre of how much of your injectors you are using. I've used like 75% of 550cc injectors on 9PSI -but that was with a smaller turbo.
Anyway before that need to get my turbo replacement first.
#59
Originally Posted by Garage1217
exactly, stock cutoff is way before 6200 and at 127mph
