is there any way?
^^ get a standalone and you can do open loop all the time, or you can unplug the O2 sensor.. but hey if you dont tune with close loop then you're missing a big part and you will still be untuned unless you go to WOT
or you could pull the 02 to go into open loop and just leave it unplugged so your always in open loop...
wait...i just saw you have the f/ic so you shouldn't have to do that...why not just get a scangague and watch when it goes into open loop?
with the f/ic, you can tune closed loop by effectively usin ghte 02 spoofing table...you tell it what voltage to send the ECU so that the ECU THINKS the 02 sensor is reading a certain AFR, but then you adjust the fuel table to run whatever AFRs you want, pretty much.
well i have my target afr's set in the o2 table. but when i get in boost at part throttle they are barely ever at where i set them to in the table. just trying to find a way to get them closer to where i want them
yes i do. my car is just constantly fighting everything i throw at it. one time i can be at 12.5 afr at 5 psi in partial throttle, the next time i can be at 10.0. it's always something different.
