Those with catless downpipes and NO CEL!!
Old 10-24-2006, 08:22 PM
Prototype_xB's Avatar
Turbonetics # 21376:
DIY non-fouler:
Prototype_xB is offline
Old 10-24-2006, 08:26 PM
Byta27's Avatar
OK !!!!!! thank you bro that answered my question that extender is ALOTTT longer than the one i have is alot shorter im gonna give tnetics a call i think.
Byta27 is offline
Old 10-24-2006, 08:28 PM
Byta27's Avatar
oh wow soo just buy one extra thing and add it do they come with the hole already made in them?
Byta27 is offline
Old 10-24-2006, 08:29 PM
I just emailed turbonetics about the extension. If they respond i'll let everyone know how much they'll charge.
Old 10-24-2006, 08:30 PM
Scion Society
TimmyT's Avatar
Originally Posted by Prototype_xB
Originally Posted by TimmyT
... The downpipe doesn't have a cat to begin with.
The exhaust manifold has a cat.. then the downpipe... then another cat.
YOu can have a downpipe and both cats. If you don't have the first cat converter, an antifouler will prevent a cel
Do people not realize this is in the F/I section? Only place to put a cat on a t/c setup is on the downpipe.
There are 2 cats.. Only way to put both cats on a turbo set up is on the downpipe.
TimmyT is offline
Old 10-24-2006, 08:34 PM
there's only 1, the second you're reffering to is actually a resonator, and its on the midpipe
Old 10-24-2006, 08:38 PM
Scion Society
TimmyT's Avatar
Omg man. Take your old exhaust manifold and look at if (if you are turbo), Now right after your downpipe you'll see something.. that is the 2nd cat...
The exhaust pipe looks something similar to this =O=<====>======
There is no flange directly after the 2nd cat. Wich is why companies like Greddy advertise thier exaust as Cat-back, Because the exhaust connects to the first flange after the 2nd cat.
I know this because I installed my Magnaflow cat-back exhaust myself. And you have to cut the exhaust pipe 3" after the 2nd cat.
TimmyT is offline
Old 10-24-2006, 09:01 PM
Stock header+cat:
*Houses primary O2 sensor*
S-pipe (follows header):
Secondary 02. Hmmm, i don't see any 2nd cat. A second cat would not follow after the sensors. The lump you're referring to on this section of the vehicle *not pictured*(aftermarket mid-pipe) is the one and only resonator on the exhaust system:
Old 10-24-2006, 09:06 PM
Scion Society
TimmyT's Avatar
Okay well here it goes gotta show yah myself cause you can't find it and I don't know how to describe it better.
Click on the link and you'll find some better pictures. I guess better than real life.
http://www.magnaflow.com/07techtips/pdfs/16640.pdf
also since 1995 and the OBD II system. I don't recall any passenger vehicle that did not have 2 catalytic converters.
And why are you showing pictures of an aftermarket exhaust system to prove something about a stock exhaust system?
TimmyT is offline
Old 10-24-2006, 09:35 PM
Byta27's Avatar
OK guys i just got off the phone with tnetics he said that the one they supply with there kit is 3 and half inches long and they sell for 50$ i dunno if i should buy it or not i think im just gonna run to pepboys and pick one up for 3 $ and see if that works if not i will order it .
Byta27 is offline
Old 10-24-2006, 09:53 PM
3.5" huh? I have an assembled DIY HELP! antifouler right here. Measure 2 1/16" together and 1 1/2" alone. If you add one more it'll make the overall 3 and 9/16" long (3.6"). PERFECT!
Old 10-24-2006, 11:47 PM
ERIC-TC's Avatar
On a tC with fsctoty S-Pipe and factory mid-pie... Right after the S-pipe there is a secondary cat (GA3) immediately followed by a longer resonator.
I've got the ZPI kit with (2) of the help brand anti-foulers with the gasket. The one closest to the sensor is drilled out.
Have not had any CEL's , even when I installed the BOV.
ERIC-TC is offline
Old 10-24-2006, 11:54 PM
zer0's Avatar
DIY non-fouler:
Nice pics.
zer0 is offline
Old 10-25-2006, 12:29 AM
Byta27's Avatar
ya im gonna run to the store for that one more i need what is the exact piece i need whats the part number or what it called soo i know what to ask forr??????
Byta27 is offline
Old 10-25-2006, 01:33 AM
zer0's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=133615
zer0 is offline
Old 10-25-2006, 02:56 AM
yamaha16bw's Avatar
Another thing about the Turbonetics o2 extendor is that the end that screws into the s-pipe has a hole on the inside like all antifoulers but it is very very small. I used the other anitfouler mods for my DC headers on our RS2 and the Tnetics hole is about the size of a Tic-Tac where the "other" one has a hole the size of a gobstopper.....sorry its the only things that came to mind to compare too lol.
yamaha16bw is offline
Old 10-25-2006, 03:16 AM
HELP! Brand # 42002
#42009 are shorter, don't use those.
Old 10-25-2006, 03:19 AM
which non-fouler is that? Hows the size of the tnetics compared to the Help brand non fouler?
DIY non-fouler:
Old 10-25-2006, 03:30 AM
yamaha16bw's Avatar
Maybe I'm wrong....it was awhile ago. I could of swore that the hole was bigger on the Help brand compared to the tnetics. Either way the tnetics is quite a bit longer even with 2 help non foulers installed.
Old 10-25-2006, 03:38 AM
Byta27's Avatar
im planning on putting on 3 just to make it longer like the tnetics hey it beats out 50$ any day those help brand one are 3 $ i have 2 now on there and im throwing a cell so if i throw one more of those on there the one with the smaller hole it would be just as long as the tnetics and i should be fine
Byta27 is offline
Quick Reply: Those with catless downpipes and NO CEL!!
