for those who think their tune is conservative....
Old 12-10-2009, 04:52 PM
cburglb34's Avatar
Default for those who think their tune is conservative....
try beating this... look at how much timing im pulling and look at the fuel map
cburglb34 is offline
Old 12-10-2009, 04:54 PM
bdis3's Avatar
What's your point? I can go pull 2 degrees of timing for every pound of boost, but who cares?
bdis3 is offline
Old 12-10-2009, 05:29 PM
XIEmperorIX's Avatar
..I don't get it
XIEmperorIX is offline
Old 12-10-2009, 05:32 PM
SoFloTC's Avatar
uhh thread fail.
SoFloTC is offline
Old 12-10-2009, 05:38 PM
cburglb34's Avatar
because theres always those tools who say oh im running a conservative tune,blow their motors and wonder what went wrong....ive seen people only pull 1.5 at like 23psia ....claiming they are consevative and at a 12.4 afr
Old 12-10-2009, 05:51 PM
ElevationTC's Avatar
Your accually pulling timing to the point its almost to much..
-6 degrees at 10 psi is overkill!
ElevationTC is offline
Old 12-10-2009, 05:54 PM
cburglb34's Avatar
yes mike but seeing as im only set for 6.5-7psi ......lol i have it to pull lots of timming and add lots of fuel if i ever go 10psi
if your wondering why my boost is low its because i have stock clutch and pushing its limits
Old 12-10-2009, 06:33 PM
dave2610's Avatar
ummmmm
dave2610 is offline
Old 12-10-2009, 07:09 PM
highvoltage1's Avatar
Dude Pie charts are so much better!
highvoltage1 is offline
Old 12-10-2009, 07:12 PM
SoFloTC's Avatar
lmao. bro. the question is why are u so conservative at such a low psi? ur ____ must move like a dog
SoFloTC is offline
Old 12-10-2009, 07:16 PM
BTW I was serious when I said I don't get it lol how does this affect a tuning exactly? What exactly is the timing doing for the car in this case?
I know absolutely jack ____ about tuning
Old 12-10-2009, 07:17 PM
cburglb34's Avatar
im still workin on my tune... i know in the dsm world when using dsm link they advise pull 3 degree of timing and adjust air/fuel till its perfect then go back to timing and add where it needs it
Old 12-10-2009, 07:20 PM
cburglb34's Avatar
you pull timing to reduce the risk of detonation/ predetonation(knock)
down side to this is car will get slower
Old 12-10-2009, 07:32 PM
B_Real45's Avatar
Have you even logged a stock TC yet to know what timing is stock?
If not, you won't know what timing you're truly running - only X amount less than stock. That's useless..
B_Real45 is offline
Old 12-10-2009, 08:47 PM
cburglb34's Avatar
im going based off the rule of thumb for boost....1 degree retard per 1 psi usually after 5psi
so......your comment was useless....
Old 12-10-2009, 09:50 PM
B_Real45's Avatar
Lol whatever you say. Your math isnt even right.
B_Real45 is offline
Old 12-10-2009, 10:14 PM
isnt it 1 degree for every 2 degrees?
cburglb34's Avatar
your right im pulling 1 degree per each PSIA after 19psia, 19= 4.3psi
this is done for simplicity and im still fine tuning it, im still limited by salty, wet roads, i dont see you tuning your own car..
Old 12-10-2009, 10:26 PM
chintastictc's Avatar
your a funny guy lmao....remember that thread u called out all the zpi turbo tCs to race your ebay turbo kit? lmfao ur threads are priceless hahahahaha
chintastictc is offline
Old 12-10-2009, 11:47 PM
m6ar2cel6oTC's Avatar
Lol this is a useless thread. And b_real does tune his own car. And stOck clutch can hold almost 300. I replaced my stock clutch at I think 285 trq. And I beat the crap out of it. And like b_real said you need aimethin to see how much iming your running i'd you don't know then you should find out.
m6ar2cel6oTC is offline
Quick Reply: for those who think their tune is conservative....
