Tial Wastegate not opening
So i bought a new tial wastegate 38mm (one of the older bigger silver ones) and i hooked up the vacuum line to the side of the wastegate. I was on half throttle and noticed my boost going up to 14-16psi. I have a .5 bar spring and i opened up my wastegate and made sure it is a .5 bar. im wondering if it would work if i hook up the vacuum line to the top of the wastegate instead of the side because the first tial wastegate i bought, i believe the vacuum was attached to the top and i thought it was broken because it was opening up so i bought this new one, and now that the vacuum is on the side, its not opening up at all. any ideas?
oh and theres 4 set screws that hold that on the valve makes sure they are there n tight
well i just took the wastegate off, and for a .5 bar spring, that piston on the bottom is pretty tight to push.... it took two thumbs and a lot of pressure before that piston moved... i think ill open it up when i get home
SloTC1
08-16-2018 02:45 PM
airmankevin1
11-17-2015 05:44 AM
crimson_sinn
09-25-2015 09:41 PM
