too good to be true?
Team Scionara
try these
http://www.dezod.com/pd_deatsch.cfm
they are plug and play, no cutting/splicing to be done. just pop em in and plug em up.
That price is for each injector.
I have used RC injectors on the 2AZ-FE before and if you don't double up the o rings, which I ended up having to use older GM (89 camaro) o rings to seal the injector against the head they won't seal good enough and you will get a boost leak and possible vacuum leak. They don't seal the same way the OEM designed densos do.
Good injectors though.
if for some reason you just gotta have rc injectors these are a little cheaper (this is each and not a set)
http://www.erzperformance.com/RC_Injectors_s/1906.htm
bushdog
02-22-2015 03:04 AM
