TPS wire...
TPS wire...
almost done hooking up my ny-trex triple threat nitrous kit... need to tap into the TPS wire above the pedal... i have read it is the brown wire that i want, just wanted to check with everyone else to see if this is the one they used
I'll email you the pinout guide for the 07+ tC's. It should be the same for 09. Email me at joe@dezodwest.com and I will reply with the attachment.
does it show u on the unit itself the pin numbers? ... also, i want to tap into the wire that is above the accelerator pedal, not the one in the engine bay by the throttle body... does this make a difference cuz i think the one u suggested is by the throttle body
what do u mean use the one from the ecu? that doesnt make sense... there are the throttle position sensor wires by the throttle body, then the pedal position sensor wires above the pedal... the wires are the same colors for both, and i just want to tap into the pedal ones... im asking if anyone knows for sure if it is the brown wire that controls the voltage of the throttle and pedal sensors..
Sgtfluffy16
Scion tC 1G Wheel & Tire
77
12-17-2023 08:09 PM
dtpmike
06-20-2010 10:26 AM
GreenEnvy06
Scion xB 2nd-Gen Wheel & Tire
10-11-2007 02:32 PM
-lastsciontc-
21
07-09-2007 11:19 PM
