TRD Boost Gauge: Problems.....
Hello,
Well..I installed my TRD boost gauge and I followed this
https://www.scionlife.com/forums/vie...ghlight=gauges
but when I finished my car at idle read 20 IN.HG...and as i hit the gas it goes towards PSI...
Is this correct....
Is this correct....
Same with mine, but I haven't totally punched it since I don't know if I adjusted my BPV properly. But you did install it correctly. It's pretty accurate, but the closer you do it to the throttle body, the more accurate the reading.
yes it is true, becaues if you were below the vac then that means your car died. so it should be idling somewhere other than the last vac point and when you start pressing the gas it'll increase until 0 then once you hit boost you'll be in the psi
Greg S
07-21-2016 07:28 PM
