trd reflash
Team No Limitz
plus the A/F ratios would probly be way off...the Camrys are tuned down and only put out about 155hp. The California ones put down even less if Im not mistaken due to emissions.
A map is a map is a map. Thet're not modifying the current map, they're re-falshing it with a new one. No you cant use TC ecu on a Camry or a Camry ecu on a Tc. The ecu controls more than just the engine in many cases and this is one of them. The tc and camry have different options so cant simply plug it in. You can re-flash the ecu but it has to be the one that came with the car or the same kind of car. go to toyota or send your ecu to ZPI or get a custom tuned uni-chip.
rain7905643
06-13-2018 05:29 AM
airmankevin1
11-17-2015 05:44 AM
