TRD Reflash question
Old 09-09-2007, 11:43 PM
Sleep3r's Avatar
fill up at least 4.5 quarts of oil 5w-30 synthetic or 10w-40 doesnt matter. supposedly the 10w-40 being a little thicker will reduce the chatter noise on the S/C at idle.
you drain the radiator fluid. the manual tells you to pour it back in but i just drain the whole thing and bought some more from toyota. make sure you only use the pink coolant. premixed long life one. or you can get the red and mix it with water 50/50 yourself. same thing.
Sleep3r is offline
Old 09-10-2007, 12:50 AM
kikcaffine's Avatar
Your supposed to change out the thermostat, but I never did. My car doesnt seem to mind though.
kikcaffine is offline
Old 09-10-2007, 01:41 AM
Sleep3r's Avatar
i suppose after changing the thermostat, the fan seems to be turning on more often now at idle, temperature is fine though
Sleep3r is offline
Old 09-10-2007, 07:18 AM
ScottTc13's Avatar
Yeah you have to change out the oil, I used 10 40. And at 90k you might want to replace your coolant. I think it is suggested to be changed at 100.
ScottTc13 is offline
Old 09-10-2007, 04:48 PM
gwtc's Avatar
Cool, thank you all for all your help.....
gwtc is offline
bootlgr
01-26-2016 01:22 AM
Greg S
05-28-2015 12:46 AM
GoodVibes
Scion xB 2nd-Gen Wheel & Tire
03-03-2015 09:47 PM
TotalChaos
13
02-04-2015 10:24 PM
fearturtle44
15
02-13-2004 01:15 AM
Quick Reply: TRD Reflash question
