TRD Reflash + right size turbo and injectors.. does it work?
Originally Posted by unxpectederror
well i imagine it would do a slightly better job then the stock ecu normally does, no?
i don't understand how the reflash wouldn't be a safer starting point then the stock ecu program
and the reflashed ecu will work like the stock one but still you should baby the car like how you do when only running stock ecu.. doesnt mean its reflashed its okay to be boosting on it coz it has a performance tuned ecu, the reflash is still not designed for setup and its same as untuned.. thats the reason why some map works very well with one setup but will blow the motor of another car with a different setup
unxpectederro,
Please listen to what we're saying.. and please read this post carefully:
1.) I understand what you're trying to say regarding the S/C for our cars is "like" a turbo.. but the similarity is only that both are Centrifugal.. meaning they spin wheels on an axle and compress air using centrifugal force. Other than that, they are totally different. S/C is belt driven - so psi is directly related to RPM. A turbo is exhaust driven - it just needs enough exhaust to hit max boost and a wastegate maintains it there.
2.) A tune from TRD is going to have a very linear tune with respect to AFR. This is because boost and CFM are increasing in relation to RPM. With a turbo, CFM does increase in relation to RPM, but RPM is only one factor - the other is boost level (independent of RPM) and efficiency range.
3.) If you want to get a piggy-back ECU, don't even bother with the TRD tune. If you want to have closed-loop (partial throttle) to be tuned, stick with an AEM F/IC or a Unichip.. those two can tuen partial throttle. With a Greddy eManage, I believe you need the "black box" to do this.
4.) Don't try to cut corners. Spend good money on management and tuning.
^^ exactly..
but for your question will it work? since it hasnt been tried yet, maybe but most likely not.. but is it worth a shot? no, motor is expensive you know..
but if you want to give it a try and prove many wrong, use the trd reflashed ecu and use the recommended injectors for that reflash, choose the turbo well and limit your boost.. stock ecu worked for the stage 0 but not a good way to put a turbo
sorry guys i did mean closed loop, i was very tired last night and my brain wasn't firing on all cylinders haha.. but of course you already know this ;)
and B_Real45
1. i know this that's why i said its similar to a turbo... didn't say it was the same thing.
2. see things like this are what i wanna hear
3. i thought even if you do tune for partial throttle the ecu will just relearn its old ways?
CarbonXe... thanks for the pretty picture
btw guys this was just a post to find out the capabilities of the trd flash.
thanks for the insight so far
and B_Real45
Most of what these guys are saying is true...
dont cut corners....for 98% of the people on this board.
I have customers who buy the correct fuel management, install the kit, think they can install the fuel stuff later....blow there motor and its my fault.....but....
You can use the REFLASH and the injectors(410-440cc) and a small wheel T3/T4 (or a GT28rs for convos sake) at no more than 5 psi and have an awesome tune/powerband.
It actually works well on the stock ecu as well..just dont boost more than 5psi.
I have a car here in AZ thats been running now for almost 2 years on the stock ecu and 440cc injectors at 5psi on a GT28RS and it runs like stock and is a blast to drive.
I dont like promoting it...but it does work and so to answer your question....YES
Regards-
Todd
Regards-
Todd
Regards-
Todd
Regards-
Todd
^^ if you want only low boost always get the run the softest spring 2 or 3 psi, also consider that boost creep could happen and yeah get a boost controller to get it properly dialed to 5
i have had the trd reflash ecu on my car after i went turbo and it sucked!!!!!! it would pull ridiculous amounts of timing!!! and idles rough!!! the reflash will nto work point blank. take it from me that i had it! and tuning the reflash with the turbo robbed me power like crazy lets just say when i had the reflashed i dynoed at 270whp and 300 torque now with m stock ecu i dynoed at 317whp and 319 torque! on a conservative tune i think lol. when i had the reflash it was a aggressive tune cause i wasnt making anypower with my turbo on the reflash! so don waste your time. but if you do wanna try you can buy my reflash that i still have for cheap for ____s and giggles
you gotta think man. the turbo will hit 7-9 psi at 2200 RPM. the S/C is only making 3 or 4 then. so the flash is only going to dump fuel for 3 or 4 psi not 7. the trd reflas would be a great tune for that much.... at red line. IF you god a turbo that flowed the same CFM but that would be a VERY small turbo. we're talkin like a KO3A off a 1.8 vw/audi
Here.
As simple as I can put it.
