TRD S/C - ISSUES SURVEY - ROLL CALL - **Please chime in**
Old 09-06-2006, 02:33 PM
jetlounge's Avatar
Default TRD S/C - ISSUES SURVEY - ROLL CALL - **Please chime in**
This is a technical survey, as best as i could do to try to get a handle on who has the TRD S/C and the level of success or failure with the unit. I know there are other roll calls, but they speak to the 'warm and fuzzies' and levels of satisfaction. With the number of issues in various threads here i thought it would be good to compile the good, the bad and the ugly. If you have the time, please make copy/paste of the survey so we can get some metrics. When the results are in, perhaps we can see if there are any common issues. If you have had more than 1, please make 2 separate posts.
SURVEY AND SAMPLE ENTRIES
A) VEHICLE
1. Year: 2005 / 2006
2. Transmission: AT / MT
3. State: NY / VA / NJ, etc
B) INSTALLATION
1. Installed by: Dealer / Self / Pro Mechanic
2. Purchased thru: Dealer / Online
3. ECU Flash done prior to driving: Y / N
4. Date of Install: 1/1/06
5. # of miles @ time of install: 5,000
C) OTHER MODS:
1. Header: Y / N
2. Aftermarket S/C Pulley: Y / N
3. Other Aftermarket Pulleys: Y/N . If yes, please list
4. BPV/BOV: Y/N
5. CAI: Y/N
6. ECU Piggyback: Y/N
7: Belt upgrade: Y/ N
8. Did you have to remove, then replace any s/c components (ie, to gain access) when adding the mods above? Y / N
9. Clutch/Flywheel: Y/N
10. Torque Dampener: Y/N
11. Motor Mounts: Y/N
12. Intercooler: Y/N
13. Water/Meth: Y/N
14: Nitrous: Y/N
D) PROBLEMS:
1. Leaking oil: Y / N
Only answer the following if answered Y above
a. Noticed after # miles:
b. Rectified: Y / N
c. Rectified by: Dealer / Self / NA
d. Method to fix: OPEN TEXT COMMENT
2. Cracked Shaft mount: Y / N
b. Rectified: Y / N
3. Cracked S/C Transmission Mount: Y / N
b. Rectified: Y / N / NA
4. Other Problem: Y / N
E) OTHER
1. Gas Octane used:
2. Oil / viscosity / brand used:
3. Driving: Mostly Highway / Mostly City
4. I consider myself: Conservative Driver / Lead Foot / Only Mash to Get on the Highway
F) OPEN TECHNICAL COMMENTS (OPTIONAL)
(about the operation of the system, not emotional grievances)
Revision List:
- 9/6. Good call by IceNine, added more to the mods list, and additional problem: cracked s/c Mount
jetlounge is offline
Old 09-06-2006, 02:45 PM
IceNine's Avatar
Default Re: TRD S/C - ISSUES SURVEY - ROLL CALL - **Please chime in*
NOTE: YOU SHOULD ADD A LINE FOR TRANNY/CLUTCH/FLYWHEEL MODS and for TORQUE DAMPENERS/MOTOR MOUNTS!! They may be relevant, as may Methanol/Water injection. Also, there are 2 mount points reportedly breaking - the shaft mount as you have listed, but also the Supercharger Mount to the transmission, which is way more widespread than the shaft/pulley mount.
A) VEHICLE
1. Year: 2006
2. Transmission: MT
3. State: NJ
B) INSTALLATION
1. Installed by: Dealer (Liberty Toyota)
2. Purchased thru: Online (TRD Sparks)
3. ECU Flash done prior to driving: Yes
4. Date of Install: 5/15/06 (est)
5. # of miles @ time of install: 2,000
C) OTHER MODS:
1. Header: Y (Alphawerks with Jet-hot Sterling)
2. Aftermarket S/C Pulley: Yes (NST 9.5)
3. Other Aftermarket Pulleys: Yes (NST 20% Alt, WP)
4. BPV/BOV: Yes (Bosch Sport 110
5. CAI: N
8. Did you have to remove, then replace any s/c components (ie, to gain access) when adding the mods above? N (noticed BEFORE install of flywheel)
9. Clutch/Flywheel: Yes (Fidanza)
10. Torque Dampener: Yes (Ingalls Stiffy)
11. Motor Mounts: N
13. Water/Meth: Yes (Rippmods)
14: Nitrous: N (Bottles are for babies)
D) PROBLEMS:
1. Leaking oil: N
2. Cracked Shaft mount: N
3. Cracked S/C Transmission Mount: Yes
a. Noticed after # miles: 9000
b. Rectified: No (soon)
c. Rectified by: Dealer (when done)
d. Method to fix: Direct replacement
4. Other Problem: N
E) OTHER
1. Gas Octane used: 93
2. Oil / viscosity / brand used: Mobil 1 5w30
4. I consider myself: Only Mash to Get on the Highway
NA
IceNine is offline
Old 09-06-2006, 04:47 PM
PghtC's Avatar
no problems. Sorry don't have time right now to fill everything in.
PghtC is offline
Old 09-06-2006, 05:24 PM
ryno379's Avatar
A) VEHICLE
1. Year: 2006
2. Transmission: MT
3. State: PA
B) INSTALLATION
1. Installed by: Allegheny Toyota/Scion
4. Date of Install: 2/06
5. # of miles @ time of install: 994
C) OTHER MODS:
1. Header: N
2. Aftermarket S/C Pulley: Y(ZPI 9 psi)
3. Other Aftermarket Pulleys: N
4. BPV/BOV: Y(Bosch 110)
5. CAI: N
6. ECU Piggyback: N
7: Belt upgrade: N
9. Clutch/Flywheel: N
10. Torque Dampener: N
11. Motor Mounts: N
12. Intercooler: N
13. Water/Meth: N
14: Nitrous: N
D) PROBLEMS:
1. Leaking oil: N
a. Noticed after # miles:7000
b. Rectified: in process
d. Method to fix: new bracket on order
4. Other Problem: N
E) OTHER
2. Oil / viscosity / brand used: Mobil 1 synthetic 5w30
3. Driving: mix if highway and city
4. I consider myself: I take time to blow out the cobwebs daily
ryno379 is offline
Old 09-06-2006, 05:27 PM
Nick06tC's Avatar
watching. I will post up my answers later on.
Nick06tC is offline
Old 09-07-2006, 01:21 AM
jetlounge's Avatar
evening bump. come on.. let's all share and learn...and then we can sing kumbaya around the campfire.
Old 09-07-2006, 01:51 AM
PghtC's Avatar
A) VEHICLE
1. Year: 2006
2. Transmission: MT
3. State: PA
B) INSTALLATION
1. Installed by: Bob Massie Toyota/Scion
2. Purchased thru: Dealer - At TRD Sparks price
4. Date of Install: 04/2006
5. # of miles @ time of install: 11,500
C) OTHER MODS:
1. Header: N
2. Aftermarket S/C Pulley: N
4. BPV/BOV: Bosch 110
5. CAI: N
6. ECU Piggyback: N
7: Belt upgrade: N
11. Motor Mounts: Y - Filled mine with urethane
12. Intercooler: N
13. Water/Meth: Soon... it is on my shelf
14: Nitrous: N
D) PROBLEMS:
1. Leaking oil: N
3. Cracked S/C Transmission Mount: N
4. Other Problem: N
E) OTHER
2. Oil / viscosity / brand used: Valvoline Syntec 10w40
3. Driving: Mix
4. I consider myself: Only Mash to Get on the Highway and occasionally around town
Nope
PghtC is offline
Old 09-07-2006, 02:02 AM
Nick06tC's Avatar
A) VEHICLE
1. Year: 2006
2. Transmission:MT
3. State: VA
B) INSTALLATION
4. Date of Install: 27/11/05
5. # of miles @ time of install: 2,000 est
C) OTHER MODS:
1. Header: N
4. BPV/BOV: Y
5. CAI: N
6. ECU Piggyback: N
7: Belt upgrade: Y
11. Motor Mounts: N
12. Intercooler: N
13. Water/Meth: N
14: Nitrous: N
D) PROBLEMS:
1. Leaking oil: N
b. Rectified: Y / N
b. Rectified: Y / N
4. Other Problem: N
E) OTHER
2. Oil / viscosity / brand used: dealer
3. Driving: Mostly City
4. I consider myself: Only Mash to Get on the Highway and some spirited get up and goes. I drag race occasionaly, and autocross occasionally.
The clicking and clacking of the turbine scares me bad.
Nick06tC is offline
Old 09-07-2006, 07:07 AM
06SuperWhite_SoCal_tC's Avatar
A) VEHICLE
1. Year: 2006
2. Transmission: MT
3. State: CA
B) INSTALLATION
4. Date of Install: 8/16/06, I think
5. # of miles @ time of install: 9400
C) OTHER MODS:
1. Header: MMW
2. Aftermarket S/C Pulley: NST 9.5psi
3. Other Aftermarket Pulleys: No
4. BPV/BOV: Stock
5. CAI: No
6. ECU Piggyback: No
7: Belt upgrade: Yes
8. Did you have to remove, then replace any s/c components (ie, to gain access) when adding the mods above? No
9. Clutch/Flywheel: Stock
10. Torque Dampener: No
11. Motor Mounts: No
12. Intercooler: No
13. Water/Meth: No
14: Nitrous: No
D) PROBLEMS:
1. Leaking oil: No
b. Rectified: Y / N
b. Rectified: Y / N
a. Noticed after # miles: 600
b. Rectified: Not Yet
c. Rectified by: Not Yet
d. Method to fix:
4. Other Problem: No
E) OTHER
1. Gas Octane used: 91, CA sucks.
2. Oil / viscosity / brand used: Mobil 1 Full Synthetic 5w 30
3. Driving: Mixed
06SuperWhite_SoCal_tC is offline
Old 09-07-2006, 11:25 AM
PghtC's Avatar
what is this cracked transmission mount issue? I have not heard of it and now I see two people have had the problem?
PghtC is offline
Old 09-08-2006, 02:27 PM
Team No Limitz
Simplyscion's Avatar
A) VEHICLE
1. Year: 2006
2. Transmission:MT
3. State: NY
B) INSTALLATION
1. Installed by: smithtown Scion
4. Date of Install: 11/05
C) OTHER MODS:
1. Header: Y
3. Other Aftermarket Pulleys: Y/ NST lightweight crank
4. BPV/BOV: Y
5. CAI: Y
6. ECU Piggyback: Y/unichip/not installed yet
7: Belt upgrade: Y
11. Motor Mounts: N
12. Intercooler: N
13. Water/Meth: Y/not installed yet
14: Nitrous: N
D) PROBLEMS:
1. Leaking oil: Y
a. Noticed after # miles: 3000 miles
b. Rectified: N/havent brought it in yet
c. Rectified by: NA
d. Method to fix: bringing into dealer for warranty
2. Cracked Shaft mount:N
b. Rectified: Y / N
4. Other Problem: N
E) OTHER
2. Oil / viscosity / brand used: 5w30 in the beginining...10w40
4. I consider myself: Lead Foot...i beat the snot out of this thing
Simplyscion is offline
Old 09-08-2006, 02:31 PM
IceNine's Avatar
See here
IceNine is offline
Old 09-08-2006, 05:02 PM
PghtC's Avatar
That's the transmission mount huh? Well then what is the cracked shaft mount then??? I thought that was the "Cracked Shaft Mount"
PghtC is offline
Old 09-08-2006, 05:05 PM
IceNine's Avatar
crack shaft mount is on the other end, near where the pulley attaches.
IceNine is offline
Old 09-08-2006, 05:07 PM
PghtC's Avatar
ok that is the one I have never heard of. Wouldn't even know where to look for that one. Oh well. I don't have any of the other problems either. I suppose one day I will.
PghtC is offline
Old 09-08-2006, 10:37 PM
Robs_tc's Avatar
A) VEHICLE
1. Year: 006
2. Transmission: MT
3. State: WI
B) INSTALLATION
2. Purchased thru: Online, TRD Sparks
4. Date of Install: 05/2006
5. # of miles @ time of install: 15,000
C) OTHER MODS:
1. Header: No
2. Aftermarket S/C Pulley: Yes, ZPI 9.5psi
4. BPV/BOV: No
5. CAI: No
7: Belt upgrade: No
9. Clutch/Flywheel: Yes, CM
12. Intercooler: No
13. Water/Meth: No
14: Nitrous: No
D) PROBLEMS:
1. Leaking oil: Yes
a. Noticed after # miles: 19,000 (4k on s/c)
b. Rectified: Yes
d. Method to fix: Replacement of the entire s/c assembly
2. Cracked Shaft mount: No
b. Rectified: Y / N
3. Cracked S/C Transmission Mount: No
E) OTHER
2. Oil / viscosity / brand used: Mobil 1 sythetic
4. I consider myself: Conservative Driver, shifts at 3-3500RPMs almost all the time but I do redline it from time to time
Really disapointed with the problems that are more commen than one might think.
This is a great topic for those of us that are looking to pin point the problems with the S/C. The only thing that still gets me is I had a stock header and heatshield. Only after I got my new S/C did I install the right belt, Botch Sport 110, and Stiffy.
Robs_tc is offline
Old 09-09-2006, 04:40 AM
jrussell98003's Avatar
A) VEHICLE
1. Year: 2006
2. Transmission: MT
3. State: Washington State
B) INSTALLATION
1. Installed by: Dealer (Scion of Lake City, Seattle)
4. Date of Install: 4/2006
5. # of miles @ time of install: 6,000
C) OTHER MODS:
1. Header: N
4. BPV/BOV: N
5. CAI: N
6. ECU Piggyback: N
7: Belt upgrade: N
8. Did you have to remove, then replace any s/c components (ie, to gain access) when adding the mods above? NA
11. Motor Mounts: N
12. Intercooler: N
13. Water/Meth: N
14: Nitrous: N
D) PROBLEMS:
1. Leaking oil: N
4. Other Problem: N
E) OTHER
1. Gas Octane used: 92
2. Oil / viscosity / brand used: 5W-30
3. Driving: 50/50 mix city/highway
4. I consider myself: I didn't buy a supercharger to accelerate slowly...
No mods and no problems.
jrussell98003 is offline
Old 09-10-2006, 04:37 PM
Garage1217's Avatar
A) VEHICLE
1. Year: 06
2. Transmission: Mt
3. State: Az
B) INSTALLATION
1. Installed by: SELF
2. Purchased thru: ONLINE
4. Date of Install: ?? ABOUT 8 MONTHS AGO?
5. # of miles @ time of install: 7k
C) OTHER MODS:
1. Header: Y
3. Other Aftermarket Pulleys: SC, WP, ALT, CRANK
4. BPV/BOV: BOV - RECIRC
5. CAI: Y
6. ECU Piggyback: N
7: Belt upgrade: Y
11. Motor Mounts: N
12. Intercooler:N
13. Water/Meth: N
14: Nitrous: N
D) PROBLEMS:
1. Leaking oil: N
a. Noticed after # miles: nOTICED AT 7k
b. Rectified: Y
c. Rectified by: SELF, DEALER WAS A JOKE
d. Method to fix: HAD IT PRO WELDED
4. Other Problem: N
E) OTHER
1. Gas Octane used: 91 SHELL
2. Oil / viscosity / brand used: 10W40
3. Driving: HWY AND CITY EQUAL
4. I consider myself: CONSERVATIVE DRIVER MOST OF THE TIME
LOVE THE SC
Garage1217 is offline
HighlanderMac's Avatar
A) VEHICLE
1. Year: 2006
2. Transmission: MT
3. State: TX
B) INSTALLATION
4. Date of Install: One in November of 2005, One in July of 2006 I think
5. # of miles @ time of install: One with like 700 miles, and one with like 6,000
C) OTHER MODS:
1. Header: Before I put on the Second SuperCharger
2. Aftermarket S/C Pulley: Y 9lb ZPI
4. BPV/BOV: Y Bosche 110
5. CAI: Y, Kind of, it is actually an SRI
6. ECU Piggyback: N
7: Belt upgrade: N
11. Motor Mounts: N
12. Intercooler: N
13. Water/Meth: N
14: Nitrous: N
D) PROBLEMS:
1. Leaking oil: Y On the First S/C
a. Noticed after # miles: 5,000
b. Rectified: Y, Had to buy an entirely new SuperCharger Unit
c. Rectified by: Dealer and Self
d. Method to fix: Had to get a whole new SuperCharger kit, 3600 after taxes.
b. Rectified: N
c. Rectified by: NA
d. Method to fix:
a. Noticed after # miles: 10,000
b. Rectified: NA
c. Rectified by: NA
d. Method to fix: They better not give me any problems with warranty on this one.
4. Other Problem: N
E) OTHER
2. Oil / viscosity / brand used: Castrol Syntec 10W30
3. Driving: Both Highway and City
4. I consider myself: A Driver who drives for fun, Lead foot.. lol
I am beginning to think this was a waste of money. Not just for the SuperCharger, more or less for giving my money to TRD. Again, moving them further back on my list of good wholesome companies.
HighlanderMac is offline
Old 09-11-2006, 02:48 PM
cessblood's Avatar
I will answer the questions when I get home from work.
cessblood is offline
Quick Reply: TRD S/C - ISSUES SURVEY - ROLL CALL - **Please chime in**
