TRD S/C - ISSUES SURVEY - ROLL CALL - **Please chime in**
Old 09-11-2006, 02:53 PM
cessblood's Avatar
Hey HighlanderMac. You said your on your second supercharger? what happen to your first one? if you don't mine telling me?
cessblood is offline
Old 09-11-2006, 02:57 PM
PghtC's Avatar
he had a bad oil seal that they blamed on his header and pulley. So they refused warranty, so he had to buy another one.
PghtC is offline
Old 09-11-2006, 03:38 PM
cessblood's Avatar
OUCH! I know he was Mad
Old 09-11-2006, 04:18 PM
PghtC's Avatar
a little steamed...I remember that post.
PghtC is offline
Old 09-11-2006, 04:52 PM
HighlanderMac's Avatar
Hahah , to say the least...
HighlanderMac is offline
Old 10-30-2006, 11:55 PM
PghtC's Avatar
Ok...update as of tonight. I noticed a very loud screaming sound during acceleration after picking it up at the dealership tonight after they fixed a CEL issue...wish I would have noticed it before I got 25 miles away...damn...looks like I will be calling tomorrow morning again.
A) VEHICLE
1. Year: 2006
2. Transmission: MT
3. State: PA
B) INSTALLATION
1. Installed by: Bob Massie Toyota/Scion
2. Purchased thru: Dealer - At TRD Sparks price
3. ECU Flash done prior to driving: Y
4. Date of Install: 04/2006
5. # of miles @ time of install: 11,500
C) OTHER MODS:
1. Header: N
2. Aftermarket S/C Pulley: N
3. Other Aftermarket Pulleys: N
4. BPV/BOV: Bosch 110
5. CAI: N
6. ECU Piggyback: N
7: Belt upgrade: N
8. Did you have to remove, then replace any s/c components (ie, to gain access) when adding the mods above? N
9. Clutch/Flywheel: N
10. Torque Dampener: N
11. Motor Mounts: Y - Filled mine with urethane
12. Intercooler: N
13. Water/Meth: Soon... it is on my shelf
14: Nitrous: N
D) PROBLEMS:
1. Leaking oil: N
2. Cracked Shaft mount: N
3. Cracked S/C Transmission Mount: N
4. Other Problem: Yes
Bad supercharger impeller bearing I believe. Have to take it to the dealer AGAIN!! Between this (CEL and s/c now) and the roof it is driving me nuts.
E) OTHER
1. Gas Octane used: 93
2. Oil / viscosity / brand used: Valvoline Syntec 10w40
3. Driving: Mix
4. I consider myself: Only Mash to Get on the Highway and occasionally around town
F) OPEN TECHNICAL COMMENTS (OPTIONAL)
Nope
PghtC is offline
Old 10-31-2006, 05:29 AM
mr_lore's Avatar
Default Re: TRD S/C - ISSUES SURVEY - ROLL CALL - **Please chime in*
SURVEY AND SAMPLE ENTRIES
A) VEHICLE
1. Year: 2005
2. Transmission: MT
3. State: WI
B) INSTALLATION
1. Installed by: Dealer (DonJacobs)
4. Date of Install: 2/10/06
5. # of miles @ time of install: 7000
C) OTHER MODS:
1. Header: Y (alphawerks)
2. Aftermarket S/C Pulley: Y ZPI 9psi installed by dealer day 0
5. CAI: Y K&N
6. ECU Piggyback: N
7: Belt upgrade: N
8. Did you have to remove, then replace any s/c components (ie, to gain access) when adding the mods above? N (all dealer installed)
9. Clutch/Flywheel: N Stock
10. Torque Dampener: Y Engalls
11. Motor Mounts: N
12. Intercooler: N
13. Water/Meth: N
14: Nitrous: N
D) PROBLEMS:
1. Leaking oil: N
4. Other Problem: N
E) OTHER
2. Oil / viscosity / brand used: Mobile 1 every 3-4k 10w40
3. Driving: Mostly Highway
4. I consider myself: Lead Foot
Only annoyance with the whole car is that in cold weather (sub 40) it idle hunts like made crazy for about 2-3min.
mr_lore is offline
Old 11-01-2006, 11:43 PM
emiller's Avatar
A) VEHICLE
1. Year: 2005
2. Transmission: MT
3. State: MI[b]
B) INSTALLATION
1. Installed by: suburban scion
2. Purchased thru: dealer
3. ECU Flash done prior to driving: y
4. Date of Install: july
5. # of miles @ time of install: about 20k
C) OTHER MODS:
1. Header: n
2. Aftermarket S/C Pulley: n
3. Other Aftermarket Pulleys: n
4. BPV/BOV: n
5. CAI: n
6. ECU Piggyback: n
7: Belt upgrade: n
9. Clutch/Flywheel: n
10. Torque Dampener: n
11. Motor Mounts: n
12. Intercooler: n
13. Water/Meth: n
14: Nitrous: n
D) PROBLEMS:
1. Leaking oil: n
2. Cracked Shaft mount: n
3. Cracked S/C Transmission Mount: n
4. Other Problem: n
E) OTHER
1. Gas Octane used: 91 or 93
2. Oil / viscosity / brand used: 10w30 quaker state
3. Driving: mostly city
so far so good. got over 10k on it.
emiller is offline
Old 11-01-2006, 11:54 PM
rusuden's Avatar
mine leaks oil like a faucet
rusuden is offline
Old 11-04-2006, 10:43 PM
HOLLYWD69's Avatar
It looks like I have a bad bearing. Stock header and pully so they better not give me any poop about fixing it.
HOLLYWD69 is offline
Old 11-08-2006, 02:05 PM
cessblood's Avatar
This morning when I was driving on the highway and my engine shut off. I had to the radio and stuff. I got the car to side. I try to turn back on twice and it stay on for not even second. then I check the engine and did see anything wrong. on the 3rd or the 4th time it turn back on. Did this happen to anyone before? I think the car was getting enough air into it
Old 11-08-2006, 03:37 PM
IceNine's Avatar
Check the vaccum hose that goes from your throttle body to and eventually makes its way to your bypass valve. If you aren't going to do it, at least tell your dealer to look
IceNine is offline
Old 11-08-2006, 03:54 PM
kanundrum's Avatar
A) VEHICLE
1. Year: 2005
2. Transmission: MT
3. State: MD
B) INSTALLATION
1. Installed by: Dealer (R&H Scion)
2. Purchased thru: Online (Waldorf Toyota)
3. ECU Flash done prior to driving: Yes
4. Date of Install: 6/30/06 (est)
5. # of miles @ time of install: 28
C) OTHER MODS:
4. BPV/BOV: Yes (Bosch Sport 110 )
5. CAI: N
6. ECU Piggyback: Y
7: Belt upgrade: N
9. Clutch/Flywheel: TRD Clutch
11. Motor Mounts: N
12. Intercooler: N
13. Water/Meth: NO
14: Nitrous: N
D) PROBLEMS:
1. Leaking oil: Y
3. Cracked S/C Transmission Mount: NO
a. Noticed after # miles: 3000
b. Rectified: Y
c. Rectified by: Dealer (September 06)
d. Method to fix: Blower Replacement
4. Other Problem: N
E) OTHER
2. Oil / viscosity / brand used: Mobil 1 5w30(Before Oil leak, now 10w40)
3. Driving: 50 City/ 50 Highway
kanundrum is offline
missing_image
02-07-2015 07:18 PM
cid_mcdp
01-05-2015 02:45 PM
minter66
12-15-2014 01:45 PM
Quick Reply: TRD S/C - ISSUES SURVEY - ROLL CALL - **Please chime in**
