TRD S/C maintainence and Info
here's a little info for all the s/c guys out there.
remember smaller boost pully's lead to more hp and a blown motor if not done the correct way.
all your fancy pully's and gadgets don't mean jack with out a good tune. So find a EMS that works for you.
our motor is supposed to be able to handle 300 hp with out a build, but our toothpick rods sometimes beg to differ.
9.5 boost pully's are safe to run on the TRD ECU reflash.
Never go full throttle before engine reaches normal operating temps. The s/c full operation is after the car is at normal temps for two to three minutes.
Always use 91 + octain fuel, and fuel with a lower octain level will cause detonation.
Excessive belt tension can lead to s/c or crankshaft bearing failure. Do not use non-slipping or cog-type belts.
Clean s/c oil inlet fitting every 3000 miles using high pressure air to blow the orifice clean.
Do not use oil additives which main contain solid particles that can clog the s/c feed line.
The heat sheild is used to keep excessive heat off the s/c shaft which can lead to premature seal failure.
Recommended tuning upgrades are:
Oil pressure gauge (if you were to have a cloged orifice or loose oil pressure this gauge will let you know, so you can cut off the motor and save yourself some damages.)
Air to Fuel wideband (detonation is the big killer in the F/I world so its good to maintain a proper a/f ratio)
Boost gauge
Hope this help a little for those with s/c. If there is anything else I left out just add on to it.
Boost gauge
I'm not to sure if they do make a s/c for the a/t I think I read that they do on here. try a search for it. but yes you can run the 9.5 with the trd ecu reflash. and there are cai that use can use with the sc (either mmw or you can mod one yourself) but this will lead to running a lean air to fuel ratio because your mass airflow sensor is still gonna read stock like its supposed to. ummm I don't know that if you run a EMS if you can control the mixture with a cai on the sc. if anyone has info on that please let me know. but as far as I've read they really don't give you large enough gain to even bother modding or purchasing a custom cai. either was running lean in the long term will catch up to your motor. and no I don't think the gates belt is too tight. you gotta have something a little tighter to compensate for the smaller size pully. but going much tighter to try to eliminate belt slippage is no good
nice tips..... though I wasn't aware of the need to clean the oil inlet ( and apparently neither is the service dept at the dealership who said we do not need any special maintenance on the sc ). Is it difficult to get at and take care of?
thx
thx
so instead of a CAI is it just better to run like a short ram intake. i just dont see how running a 9.5 pulley will not mess up the motor but putting a CAI will. i just want to know because i have a CAI and have not had any problems but if im hurting something i would rather just put a Short Ram and be safer with my car.
^^ though trd says we are not to use a cai w/ the sc; the regional rep ( at a recent showing of the new xb which now has the 2.4 ) said that not only would the sc become available but thought the cai as well. He was not aware of the "limits' we have on our system for the TC. I have not heard back on it so maybe the 2 won't be able to be used together.... but I figured if it can work on one scion it should on another...
well the 9.5 doesn't add too much boost the the ecu can't keep up, but while the cai won't hurt your engine right now, its still bringing in more air the the stock air box, and your ecu isn't able to balance out you a/f so running lean over a period of time is what's bad for your engine. ram air intake will do the same
I have a full Injen cai and run pretty good a/f's 14.7 cruising and 10.2 wot at redline, it does lean out a little at lower rpms if I dip into to it alot, but since I am not making much boost at all so it should't be a problem.
I had the MMW s/c intake and had problems with it. During normal everyday driving, my A/F gauge would fluctuate, then read off-the-charts lean and the ECU would pull timing, making me lose power. As long as I'm accelerating hard, the readings would be normal.
Someone else here has one and had problems with his MMW s/c intake, things went back to normal when he put the stock intake back on.
I let a friend of mine use the s/c intake and he doesn't have any problems. He says it gives a more noticeable gain than he expected. I'm not sure why it works well for some people but not others, but a wideband A/F gauge would be a wise investment, esp if anyone wants to modify the intake.
Originally Posted by Curtball
I will do a write up on cleaning the oil inlet filter
https://www.scionlife.com/forums/vie...74167&start=20
Re: TRD S/C maintainence and Info
Clean s/c oil inlet fitting every 3000 miles using high pressure air to blow the orifice clean..
ColonelSanders85
12-09-2020 09:44 AM
