TRD s/c with nitrous
I wouldnt do it personally, not without building up the block (including replacing the head gasket)
And this is coming from someone that had a STOCK S/C and STILL the motor blew! BUILD IT BEFORE MODIFYING IT
i'm still working on a way to get my EMU to work with it the way i want. i'm trying to run dry setup for a 35 shot. the EMU isn't cooporating, so i'm trying to find a solution to it. if i ran it as a wet shot it would work fine but i don't want to resort to tapping into the fuel line.
35 dry will be no problem. for 50 shot you'll get mixed answers..depending on whether or not your able to get extra fuel added (bigger injectors might be needed). i think 50 would be fine, but some will say run a wet. the reason why wet is the preferred setup is because it's more convenient if you want to run a bigger shot. i'm not running anymore then a 35 so that won't be an issue for me.
before considering any changes, think of how you can change fuel/ign adjustments to match the added "stressors". A solid tune will ensure the motor's longevity.
