TRD Shift Light Installed *Pics/Vids Pg1*
Old 10-16-2007, 08:41 PM
Nick06tC's Avatar
I wouldnt set it that low. You should be able to set it above 6000.
I know at the track, i watch the tach, and I begin my shift right after 6000 rpms. By the time my body reacts, I am right at redline. I have only hit the limiter once or twice doing it that way.
Nick06tC is offline
Old 10-16-2007, 08:44 PM
shizzzon's Avatar
well then there ya go. I figured during the 1st shift that would be valuable but after that, once you trained yourself, hehe, you'd be havin this blue light starin at ya for a sec before you shift...
i'm an auto but i still manually shift on the track because my ET times are cut by 0.2 seconds which is pretty good although my 1\8th is still the same regardless if i shift or not.
shizzzon is offline
Old 10-16-2007, 08:53 PM
kanundrum's Avatar
ok sounds good Im going on friday so lets see if I can get below a 15! :D
kanundrum is offline
Old 10-16-2007, 10:37 PM
Sleep3r's Avatar
the s/c should be high 14's correct?
Sleep3r is offline
Old 10-17-2007, 02:27 AM
shizzzon's Avatar
that is correct.
Go here for proof of that-
http://www.dragtimes.com/Scion-tC-Timeslip-10091.html
shizzzon is offline
Old 10-17-2007, 03:56 PM
cessblood's Avatar
I was thinking of buy the TRD Shift Light. just in case I do I'm going to watch this Thread
cessblood is offline
Old 10-17-2007, 04:07 PM
Sleep3r's Avatar
kanundum where u buy it at? how much?
Sleep3r is offline
Old 10-17-2007, 04:09 PM
kanundrum's Avatar
i bought it from a member on here for 160
and i took vids and pics yest ill post up tonite.
Old 10-17-2007, 07:35 PM
Resu's Avatar
good deal. I look forward to seeing it in action and where it's mounted.
Resu is offline
Old 10-18-2007, 03:56 AM
kanundrum's Avatar
bumpo pics vids added
Old 10-18-2007, 04:27 AM
etsnet's Avatar
Originally Posted by shizzzon
i would personally set it 500rpms below what you would want to shift at, which would be redline. Set it at 5700rpm.
From 2nd to 3rd, that will be a quick shift so it will be valuable there.
From 3rd to 4th and 4th to 5th, it will be slower so train yourself when you will shift during those instances.
He'll never make it to 5th gear on the track with his setup. I should say he shouldn't have to shift to 5th gear on his setup if he drives right.
etsnet is offline
Old 10-18-2007, 11:20 AM
kanundrum's Avatar
hmm maybe
Old 10-18-2007, 01:43 PM
kanundrum's Avatar
might rain tom so may not go. well see
Old 10-18-2007, 05:53 PM
kanundrum's Avatar
bumpo So set it at like 6200 ?
Old 10-18-2007, 08:22 PM
Sleep3r's Avatar
Originally Posted by Sleep3r
you should set it at 6200.
if you set it at 6500 and the light comes on you'll already hit the rev limiter.
im sticking with that! try it and let me know.
Sleep3r is offline
Old 10-18-2007, 08:39 PM
CDogbert's Avatar
If I remember correctly, there actually is a difference in where the rev limiter is between '06 and '07. The '07's have a 6500 limit, and the '06 has a 6200. The redline just didn't change.
Or am I just making things up?
CDogbert is offline
Old 10-18-2007, 09:06 PM
Sleep3r's Avatar
if thats true then it would make sense why the 07's dyno more in hp
Sleep3r is offline
Old 06-26-2008, 12:46 AM
kanundrum's Avatar
sweet
Old 06-26-2008, 02:41 AM
ElevationTC's Avatar
hows it working out!
ElevationTC is offline
Old 06-26-2008, 03:19 AM
kanundrum's Avatar
So Far Hasnt Broke and been going good.
NonStopTuning
06-29-2015 07:42 PM
mischman
01-14-2015 06:07 PM
757_BRDFLY
01-09-2015 12:29 PM
TheTripleC
01-04-2015 06:46 PM
minter66
12-15-2014 01:45 PM
Quick Reply: TRD Shift Light Installed *Pics/Vids Pg1*
