TRD Supercharger on my MODDED tC
Old 03-02-2007, 08:41 PM
BionicJuic3's Avatar
Originally Posted by BionicJuic3
Where will I be able to tune it, any local shop? Sorry for the NooB questions...
BUMP!!
BionicJuic3 is offline
Old 03-02-2007, 08:52 PM
navylife59's Avatar
Been boosting with the TRD S/C on 9PSI no probs for nearly 30K miles. Just installed a piggyback emanage to get ready for the 14.5PSI and water/meth in April. The TRD maps are rock solid that is why you better have flashed your ECM when your S/C was installed. No probs and I drive hard. Would suggest a big oil cooler spinning the TRD any faster than on a 9PSI pulley.
navylife59 is offline
Old 03-03-2007, 07:02 PM
jwaggz82's Avatar
Jeze - 14.5lbs as far as I know is the highest anywhere. I haven't heard of anything over 12. At 12lbs you run into tension pulley issues so hopefully you have a plan for that. I thought I was going over and beyond thinking about getting tuned with a 10.5lb ....and your thinking about 14.5 - let me know how that goes. Post up way before you get it done so a bunch of people watch the post grow.
jwaggz82 is offline
Old 03-04-2007, 04:55 PM
bcnu_702's Avatar
Navy, can you tell me the benefits of water/meth injection over say an intercooled system? Drop me a pm, Thanks!
bcnu_702 is offline
Old 03-04-2007, 04:58 PM
jwaggz82's Avatar
^if you are running the trd map meth wont help u much. It got me 4whp but I got it for my prep build this year. Once your tuned you can see around 15-20whp off it and keep your air a lot cooler. The ic u dont want with a s/c because you will lose boost because of the extra tubing.
jwaggz82 is offline
Old 03-04-2007, 08:37 PM
bcnu_702's Avatar
J, do you know how long the IC piping is for the turbocharged systems with intercooler?
bcnu_702 is offline
Old 03-04-2007, 10:54 PM
BlKtC05's Avatar
if you use a water/air inline i/c you will minimise the piping. i think yo uonly lose 2psi, but the boost is cooler and actually runs the same whp or greater.
BlKtC05 is offline
Old 03-04-2007, 11:20 PM
bcnu_702's Avatar
Well I relocated my battery today with a kit from summitracing, so I am on my way to test-fitting an intercooler setup for the supercharger. I was able to get dimensions on the supercharger unit as well as dimensions on where it sits in the engine bay compared to the rest of the components. Now its just a matter of finding the more efficient way of piping, and go from there. I just want to use the length of piping on a turbo-charged intercooled system as a base point to try and shoot for.
bcnu_702 is offline
Old 03-05-2007, 01:20 AM
jwaggz82's Avatar
^ check my PM because its not going to work out well ...people have tried. Methanol is the way to go. Either the snow kit or the ones turbonetics has ....i forget the name ...its a different name but its by them.
jwaggz82 is offline
Old 03-05-2007, 02:59 AM
BlKtC05's Avatar
inline i/c, its the way to go!!!! the only prob you run into is finding a place for the bpv!
BlKtC05 is offline
Old 03-06-2007, 04:38 PM
navylife59's Avatar
OK here is the deal......
I/C
PROS - Always working, no problems, consistent
CON - Installation, loss of PSI, possibilty for leaking boost
Meth/H2O
PROS - No loss of boost, no potential for leaking boost, cooler intake charge temps, the right setup can be tuned and connected to e-manage for better control.
CONS - Must be tuned for HP gains, expensive for the right setup, can cause a a severe lean condition if emtpy meth tank.
The meth injection is only good if you have a stand alone or piggy-back controller to advance your timing and increase fuel burn for more power. The TRD maps are only for 9PSI. Anymore and the motor leans out too much.
Old 03-06-2007, 06:52 PM
Where can I get my car tuned?
Old 03-06-2007, 07:18 PM
BlKtC05's Avatar
oi navylife, any pics of your water/methyl injection set up?
BlKtC05 is offline
Old 03-06-2007, 07:19 PM
bcnu_702's Avatar
x2
bcnu_702 is offline
Old 03-06-2007, 08:26 PM
jwaggz82's Avatar
x2
Im not sure what you want to see but here is ripp mods methanol kit - it hooks into the stock windshield tank so theres not much ecept a black box on the right (under the hood):
jwaggz82 is offline
Old 03-06-2007, 08:37 PM
BlKtC05's Avatar
2 questions:
1. whats that big black thing on the end of the valve cover right above your methyl injector?
2. are you running any kind of piggyback?
BlKtC05 is offline
Old 03-06-2007, 08:56 PM
jwaggz82's Avatar
^ alarm speaker - and no piggyback yet - but that should be done this summer.
jwaggz82 is offline
Old 03-06-2007, 10:11 PM
? ? ? Help!
Old 03-06-2007, 10:46 PM
BlKtC05's Avatar
what are you tuning? if its an emanage you can do it yourself with help from ZPI, if its a unichip than look for a shop, if theres not one around than sorry, but you're S.O.L.
BlKtC05 is offline
Old 03-07-2007, 12:24 AM
jwaggz82's Avatar
tune a car by yourself ...for the first time? ...dude .... you want to see this guy blow his engine up?
jwaggz82 is offline
Quick Reply: TRD Supercharger on my MODDED tC
