TRD Supercharger - Tamper Proof Bolt Info
Old 09-13-2007, 11:17 AM
  #221
jwaggz82's Avatar
Originally Posted by osofast1
We do alot of modifying on different cars, such as srunners, supras, tc's.
we have one of the o7's and it has the key type wheel lock on it,
I simply put a 1 1/4 nut on the key and welded it and it came off without any hesitation, I then replaced it with a bolt from autozone..
very simple
I just hope the charger doesnt break again!
Our first compresser shaft stripped out or something trd said after 100 miles. hopefully they fixed it
im not sure how i missed your post. So you are saying its a normal 1 1/4 bolt - do you know how many lbs it was put on with? Any pictures of the old bolt with your weld?
jwaggz82 is offline
Old 09-13-2007, 10:11 PM
  #222
Curtball's Avatar
yes I would like to know these same answers cause as of right now I'm only hearing bs if you can't back it up. so I would think you should know the thread pitch and the torque of the bolt as well
Curtball is offline
Old 09-13-2007, 10:13 PM
  #223
Curtball's Avatar
Curtball is offline
Old 09-20-2007, 03:10 AM
  #224
jwaggz82's Avatar
bump
jwaggz82 is offline
Old 09-23-2007, 03:12 AM
  #225
jwaggz82's Avatar
bump
jwaggz82 is offline
Old 09-30-2007, 03:18 PM
  #226
jwaggz82's Avatar
bump
jwaggz82 is offline
Old 10-01-2007, 06:19 PM
  #227
jwaggz82's Avatar
I think that whoever has done this just does not see this post --- i am not buying the fact that nobody has taken it off because this site is full of "do-it-yourself'ers"
jwaggz82 is offline
Old 10-03-2007, 03:00 PM
  #228
monkeysauce's Avatar
I went to a local locksmith, they didn't want to touch it. Said that the fitting could match one of hundreds of different sockets.
monkeysauce is offline
Old 10-03-2007, 04:07 PM
  #229
jwaggz82's Avatar
^good god - are are any other locksmiths that could be asked in your area? I dont know of any in my area but im sure there has to be one somewhere
jwaggz82 is offline
Old 10-03-2007, 05:14 PM
  #230
Hudnut's Avatar
I work for SPX. We make all of the special service tools for many car makes including Toyota. The call has come into our help desk looking for the tool and I hate to say it but we don't make it. and if we don't make it, then dealer probably won't have it. The only other people that may have it is TRD.
Here's a link to all of Toyota's special service tools.
http://toyota.spx.com/
Hudnut is offline
Old 10-03-2007, 11:56 PM
  #231
jwaggz82's Avatar
^ thats some bad news for me and a lot of other people. I don't even have a warranty anymore on my s/c so I have a Flippin bolt that I can't even take off. One guy said he welded a head onto it but that sounds like BS since he has yet to post pics
jwaggz82 is offline
Old 10-24-2007, 04:09 PM
  #232
jwaggz82's Avatar
bump
jwaggz82 is offline
Old 01-24-2008, 10:59 AM
  #233
thispecialk's Avatar
so wats the news on this Tamper-proof Bolt. has anyone found the key for it. or know any website that sell the supercharger without the new Tamper-proof Bolt.
thispecialk is offline
Old 01-24-2008, 11:52 AM
  #234
unxpectederror's Avatar
why doesn't someone just make a damn key for it... seriously it wouldn't be that hard.. hell i could do it if some one had a newer s/c near me
unxpectederror is offline
Old 01-24-2008, 01:34 PM
  #235
jwaggz82's Avatar
Explain how you would go about making it
jwaggz82 is offline
Old 01-24-2008, 02:10 PM
  #236
chinito's Avatar
i think it might be feasible to utilize the spx torx socket on the trd tamperproof bolt if you file/dremel down the outer edge to match the contours of the tamperproof bolt head. you really only need to grab on the inner 6 sided star pattern of the bolt so as long as you can fit the socket inside the outer 6 sided "depression" then you should be good to go. of course dremelling down the socket will be a tad on the really hard side, since it is probably forged.
chinito is offline
Old 01-24-2008, 11:08 PM
  #237
jwaggz82's Avatar
^ nothing i own or nothing anybody i know owns that could file down what you mean
jwaggz82 is offline
Old 01-25-2008, 01:59 AM
  #238
aen
aen's Avatar
do you guys remember, a couple posts back i found a key for you guys?
to buy?
why didn't you just do it that way?
aen is offline
Old 01-25-2008, 02:40 AM
  #239
jwaggz82's Avatar
If you found a key to buy we would have bought it - simple as that.
jwaggz82 is offline
Old 01-25-2008, 02:52 AM
  #240
Kydog's Avatar
Use an air compressor powered dremel or a good diamond wheel on metal cutter and cut a few slots on the nut.
Than use a special socket for removing stripped bolts (it cuts into the bolt to grab it) and remove! It should grab pretty good if you cut some good slots in the nut. If you can, after cutting the slots try bending a few pieces outward to help the socket grab even better. Than go buy yourself a new nut!
My two cents.....
glad im going turbo and not supercharged
Kydog is offline
Quick Reply: TRD Supercharger - Tamper Proof Bolt Info
