treadstone turbo kit/ anyone have it?
Treadstone owner hear that is happy with his kit. I highly recommend getting a piggy back of some sort. I myself am gonna pick up the AEM F/IC to tune my car. Yes the kit can run safely on the stock ecu, it will run rich. As others have said, the piggy back will allow you to lean out the fuel curve and obtain more power while still being safe. But to get you started, its not absolutely necessary for ur car to run off the bat. But I must say, if ur gonna boost ur car, do it right and get a tuning device. GL, and keep us posted on what you decide to do.
I'm looking seriously at doing the same thing; getting a treadstone kit - does this kit work on an Auto? (assuming iget a tranny cooler as well)
since i only make money for the summer, do you think it would be safe to run this kit for a year to see how i like it and then possibly add the emanage later?
what about exaust? they say it runs ok on the stock one, but better on a bigger one.... how helpful would upgrading my hks axleback be? and should i change the whole thing or just get a midpipe and s pipe?
I think the kit will run fine on its own as long as you don't go over thew recommended psi till you get a piggyback.
of course a good exhaust will work wonders, a turbo exhaust prob even better.
Hey i'm digging this AEM F/IC can it be used as a "as a stand alone piggyback" or does it have to be paired with a EMS or AFC?
what about just using something like a HKS super AFR to run a turbo kit like the treadstone?
a piggy back requiers the stock ECU to work at all. a stand alone is just that it works alone you remove the stock ecu completly.
(sigh...) i knew some one would get confused about how i worded that...
what i meant was, CAN the AEM be used to run a turbo "by its self" or does it need to be paired up with some thing else(other than stock ecu) example: how DEZOD pairs up the apexi neo with their Black Box...
another question, Has Treadstone corrected the fitment issues? such as the turbo touching the fan shroud and the down pipe being too close to the oil line...
