trouble with turbo install
ok so the past 2 days i have been installing my turbo but ive run into problems already. biggest problem is i cant clock the turbo to allow clearance for intake piping... i have a ZPI stage 0 turbo with dezod intercooler piping. if i clock the turbo down it either hits the engine or the flange faces the radiator not giving me room for pipes... for those of you with zpi kits and intercooler how did you do it?
so im running no intercooler... other than that the car seems to run fine...
other problems i had was a cross-threaded AEM UEGO sensor....
and the idiot over here pluges the UEGO sensor with out bolting the spipe while car was on the lift well pipe fell and pulled out all the wires from the uego plug
so i dont know how im running right now
HELP ME....
HELP ME....
on most of the zpi stage 1 kits iv seen they have the turbo clocked with the comp outlet faceing up towards the hood and a j-pipe hooked up to outlet.
you can get replacement parts for the uego through any aem dealer.
i have no j-pipe lol id love to try and explain the insane amount of fustration i went though to make it fit!!
never again!!!!!!
i wish i could take pics but i cant find my stupid camera charger anywhere!!!!!!!!!
never again!!!!!!
il probably have a pipe made my self you should go to a muffler shop if ur luckey they will have aluminized pipes so they can make a custom one for you. on a side note man these ZPI kits are poping up all over the place lol
lol where the hell r they popping up from!!! since i got mine 4 other members have posted up all their problems jajaja i had my share of bloody problems.
speedy comeone please find your camera i can't fit this shiznit no matter how i try, might end up loosing the fans!!!! AAAARRRRGGGGHHHH and even with a j pipe it would be hellatight, ANYONE have pics? HELPPPP
Dude I looked everywhere for my charger...as for my set up I got rid of the stock fans and clocked the turbo as far down as it went which means it's outlet faces the radiator then I got a 90degree bend which is about a 3/4ths of a in. Away from my radiator then I used a hump coupler to give the pipes some flex and that gave me room to put a straight pipe to the rest of my IC kit.
The j pipe idea is the easiest but having your charge pipe go so close to the turbo housing isn't cool.
my06tc
06-25-2015 12:18 AM
TheRedBox
31
12-02-2003 04:53 PM
