TT's SIMPLE turbo kit UPDATES
Old 04-12-2008, 04:46 PM
  #801
sciontcnj's Avatar
Originally Posted by TurboToyotas
How about a gutted, motorless, tC? Could turn it into the ultimate TT machine . Probably only weighs about 1500lbs right now .
You have this available now?
Dude, take that in a heart beat....you selling it or you want to trade for a kit???
Hopefully thats not your car..
Regards-
Todd
well sorry to narc on your post todd but this will let you get that camry/solara 5th gear kit into this tC... : )
unless your dropping a supra motor in it or something like that
sciontcnj is offline
Old 04-18-2008, 02:16 AM
  #802
TurboToyotas's Avatar
Something along those lines will happen eventually......
She will be a work in progress and a serios test bed.
Regards-
Todd
TurboToyotas is offline
Old 04-18-2008, 02:21 AM
  #803
chicotunner07's Avatar
damm todd id trade my tc for the biggest custom kit u got!!
........but then what would i put it on..... LOL
chicotunner07 is offline
Old 04-18-2008, 02:22 AM
  #804
coryjames's Avatar
todd tell us whos the lucky one graced with todd welds lol
coryjames is offline
Old 04-18-2008, 04:27 AM
  #805
Team Echo
phresh47's Avatar
hey everyone well i finally got my kit installed ran into some issues i am missing 2 clamps the ones that go onto the intake pipe by the turbo....todd any help please? also my charge pipe hangs a little low? could this be because i upgraded manifolds? lastly im having tuning issues stupid tuning im hoping to get it all sorted out but well see everything seems reversed in my fuels charts instead of my inputs being negative they are all positive so i dont know what to do? im using the F/IC and i flashed it with the new 3.1 software any ideas or suggestions would help
phresh47 is offline
Old 04-18-2008, 04:49 AM
  #806
tC_2NeR's Avatar
Todd,
I called u the other day and left a message on your phone.
ill try to call again tomorrow.
and presh, what kinda tuning issues are you having? like whats wrong? im just curious cause i wanna to know if i can avoid any problems.
tC_2NeR is offline
Old 04-18-2008, 04:57 AM
  #807
Team Echo
phresh47's Avatar
well first off if your going fic i would say dont reflash to the new software yet....i would say go with the version 2 and work your way up as you cannot work your way back....as far as my issues and this is just what i have picked up from looking at the maps and watching my tuner try and tune everything.....when you open up the maps such as the fuel map all your inputs should be in negative numbers well some of them the ones that are towards the bottom of the map.....which in this case would be the values that are running when the car is out of boost. in my case all my input values are positive which means when its all said and done by the time im say at 5 pounds of boost im maxed out on how much fuel i can guve the car.....so i dont know if its just my tuner or if its the map that im using....but pretty much all my inputs that are positive in the non boosted area of the map should be negative and they are not..which caps me out on the amount of fuel i can feed the car during boost.
phresh47 is offline
Old 04-18-2008, 05:34 AM
  #808
tC_2NeR's Avatar
yes i will be using the FIC
but u said ur using a map?
was it a base map from someone or did your tuner tune it all from scratch and i just mis-understood you
tC_2NeR is offline
Old 04-18-2008, 05:24 PM
  #809
Team Echo
phresh47's Avatar
yes i got a few base maps that would get the car running......now if you go into the vegas style thread mr meaty posted a screen shot of what the fuel map looks like so i could get an idea and if you notice all of his numbers in the lower portion of the map are all negative numbers........on the other hand in my case all of my numbers are positive which creates a problem. hope that clears things up
phresh47 is offline
Old 04-18-2008, 06:14 PM
  #810
CarbonXe's Avatar
Originally Posted by tC_2NeR
Todd,
He's going to be in California til Monday.
CarbonXe is offline
Old 04-18-2008, 06:34 PM
  #811
Team Echo
phresh47's Avatar
if anyone has any input on the new software that aem put out for the fic it would be greatly appreciated...
phresh47 is offline
Old 04-19-2008, 04:05 PM
  #812
t_urbo_C_harged's Avatar
Sounds to me something is wrong with your software and that maybe you should try redownloading it. I have version 3.01 (don't have the F/IC but I like playing around with the values and plus I wanted to try out this new base map creation part) and on my fuel map after I entered in 700cc injectors (I did the injector difference thing and then it gave me the base map that I could get my car started off of but I would have to of course tune it from there) and I have negative numbers in the bottom of the map. I don't see why you don't, maybe you should try opening up the map, right click in the map and go to injector size change or try doing the setup base map portion and see what values it gives you then, maybe it is thinking your injectors are real small... just a thought. You can set up a base map for the fuel and timing map, as well as enter the max rpm your car will see and it will automatically setup the rpm range on the map for you. Let me know what you come up with.
t_urbo_C_harged is offline
Old 04-20-2008, 06:33 PM
  #813
973SleeperTc's Avatar
hey Todd my install guy has been trying to get a hold of you so we could order the "Ver 2.1 Stage 2.5 GT" kit...any idea when a good time to reach you would be?
973SleeperTc is offline
Old 04-20-2008, 07:06 PM
  #814
Syldrin's Avatar
He's out of town till monday. and probably out of the office till tuesday.
Syldrin is offline
Old 04-20-2008, 07:10 PM
  #815
oooh ok...... does he work alone or something?
Old 04-20-2008, 08:13 PM
  #816
Syldrin's Avatar
kinda. he runs the business by himself. but he has people who make the kits for him.
Syldrin is offline
Old 04-20-2008, 11:49 PM
  #817
turdbrains's Avatar
Why not throw in some gauges with the package?
I might get this instead of a supercharger.
turdbrains is offline
Old 04-21-2008, 01:28 AM
  #818
Team Echo
phresh47's Avatar
i think this is a great deal as it is with out the gauges i mean you cant expect to get everything for that price.....bump for todd i have officially hit boost in m car woo hoo
phresh47 is offline
Old 04-21-2008, 01:42 AM
  #819
Syldrin's Avatar
Would you like him to come install it for you too?
This is the best deal for a turbo you can get. i wouldn't beg for more when you're getting a smoking deal as it is.
Syldrin is offline
Old 04-21-2008, 04:16 PM
  #820
anyone of you guys have the GT3076R kit??? need some imput on it
Quick Reply: TT's SIMPLE turbo kit UPDATES
