Tuning Basics
Tuning Basics
I had some questions about our close/open loop and fuel trims system and stumble upon this. It helped me understand key points that have been mistakenly posted wrong around here.
http://www.autoshop101.com/forms/h44.pdf
This is just some, there are a lot more systems to see at that website. Best of all, Toyota based training series.
I was having some hesitation issues right before full boost, didn't think much of it 'till I realized that it was happening in close loop instead of open. Hopefully is just the map and not the sensor dirty or something (look at note in link). Might have to take a look at the changes I made a while back to the O2 map. Also when cold in open loop idle the car will go up and down in rpms, not much but enough to check what's going on in my fuel map. Didn't know that short term fuel trims only work in close loop.
So our cars run off of a closed loop system, constantly adjusting based off of the exhaust output. What kind of car/setup would be able to safely run open loop?
Not that I want to, because my assumption would be that you would have to program the ECU to the correct fuel measurement for each 250 or 500rpm gain... yes?
our car runs closed and open loop depending on situation.. most of the time our car is in close loop to keep afrs dead on despite changes in operating conditions.. our car goes on open loop on heavy throttle/wot, deceleration and cold start up
yep, only afr reading is from my uego. no fighting with the ecu, no switch over stumbles,
been riding like this for a while now in changing fl temps and crazy humidity. my afrs normally read around 13.5-14.5, i love the way my car feels
flip that ecu lol
hum, I forgot I did that with Chris to his car. Unpluged the O2 and drove while he tuned it. Got to do that with mine as well to see how my fuel map is going.
no he does not, nor do I. Only reason I was going to try it was to get the map in check and mirror the 02 map, then hook up the o2 and see how close it is.
Unrelated question, how long does the ecu stays in OPEN Loop when the car is first cold started?
I beleive until it reachs normal operating temp on the coolant thermostat. I believe Open Loop 1 is cold start, Open Loop 2 is WOT pretty much and then Open Loop 3 is when you disconnect the primary o2 sensor which makes it run at 10AFR consistent so pretty much you can disconnect the primary o2 sensor and just simply subtract fuel. I believe this is what I remember but its been a while.
wayneside
Regional - Pacific Northwest
09-23-2015 10:29 AM
