turbo exhaust housing seize causing turbine not to spin?
Old 01-10-2011, 11:12 PM
Dkfung88's Avatar
Default turbo exhaust housing seize causing turbine not to spin?
has anyone have this happened to them before? i left the turbo on the shelf after i took it off my car, and it was spinning perfectly. A few days ago, i tried to spin it but it would take a little more than usual pressure to spin the shaft. i tried to take the exhaust housing off but it would not budge at all!
Anyone have any ideas? its made by turbonetics
Dkfung88 is offline
Old 01-10-2011, 11:27 PM
crush02342002's Avatar
rust prolly has the hot side housing stuck...give it a shot of pb or wd40...let sit...rubber malet should get it off. could also just take a hammer and tap around the housing to break up the rust.
as far as the wheel, do you hear any scratching when you spin it? Im thinking you got some old oil in there thats kinda turned to sludge and thats maybe why it doesnt spin as well or its just rust on the shaft.
crush02342002 is offline
Old 01-11-2011, 02:03 AM
Dkfung88's Avatar
i was thinking of oil as well... hmm... ill try to use some wd40
Dkfung88 is offline
Old 01-11-2011, 02:26 AM
Syldrin's Avatar
+1 for crush's idea
Syldrin is offline
Old 02-03-2011, 06:05 PM
PeArLwHiTe07tC's Avatar
give it a lil tap-tap taparoo...
PeArLwHiTe07tC is offline
Old 02-03-2011, 06:18 PM
are we spamming to 50?
Old 02-03-2011, 06:48 PM
Scionetics
KAD
paul_dezod's Avatar
My guess is that it's probably sludged oil. I have seen this a few times. Simply some WD40 and some love taps should get her loose.
paul_dezod is offline
Old 02-04-2011, 09:17 AM
Dkfung88's Avatar
couldnt get it loose =( i've had a torch to it, added some wd40, ran oil through it, nope =(
Dkfung88 is offline
Old 02-04-2011, 04:43 PM
Syldrin's Avatar
did you get the turbine cover off?
Syldrin is offline
Old 02-05-2011, 04:12 AM
Dkfung88's Avatar
the only thing i cant remove is the exhaust housing.. =(
Dkfung88 is offline
Old 02-05-2011, 05:09 AM
troy2003's Avatar
well its time to either learn some more about your turbo and disassemble it, or run by a shop and see what is going on....cant imagine seals or anything would cause binding.....
troy2003 is offline
Old 02-05-2011, 03:20 PM
Syldrin's Avatar
troy that is a pretty arrogant comment. do you really think that someone is to stupid to remove 6 bolts and take the housing off? or are you mistaken and dont understand what we are talking about?
Syldrin is offline
Old 02-05-2011, 04:19 PM
can you atleast rotate the housing? if so try rotating it a few times while spraying some wd 40 on it every so often.
btw why were you taking the hot side off again? are you going to try and rebuild the turbo?
Old 02-05-2011, 04:45 PM
troy2003's Avatar
what??...how is that arrogant homeboy??....it is simply bolts, but i know i wouldnt feel comfortable tearing into my turbo, with all of the seals, and balancing on the inside....boy you are sooooo arrogant!!!, jk, relax man.
troy2003 is offline
Old 02-06-2011, 12:24 AM
Syldrin's Avatar
if you read the posts you'd notice that no one said anything about the internals of the turbo is all. he's talking about the exhaust housing being stuck to the CHRA at the moments.
Syldrin is offline
Old 02-06-2011, 01:24 AM
weezyfbayba's Avatar
YA HOMEBOY try pb blaster then make love 2 it
weezyfbayba is offline
Old 02-06-2011, 03:07 AM
Syldrin's Avatar
Syldrin is offline
Old 02-06-2011, 03:14 AM
syldrin
Old 02-06-2011, 08:31 AM
Syldrin's Avatar
My bad crush
Syldrin is offline
Old 02-06-2011, 08:59 AM
Dkfung88's Avatar
anywho.... i placed it on a vice to see if i could turn it... and no luck either.. man this exhaust housing is a pain! I'm trying to get it off so i can hopefully see if anything is causing the turbine not to spin... i've been hearing a lot about oil sludge, and if so, then i really gotta pull everything apart...
Dkfung88 is offline
Quick Reply: turbo exhaust housing seize causing turbine not to spin?
