Turbo Heat Blanket
Old 09-22-2010 | 07:02 PM
ARodvold's Avatar
Default Turbo Heat Blanket
Is it recommended? Insight
Old 09-22-2010 | 08:05 PM
Syldrin's Avatar
it isnt a bad investment at all.
Old 09-22-2010 | 09:26 PM
DezodDon's Avatar
Anything you can do to keep the heat in the exhaust system and lower under hood temps will help efficiency.
Old 09-22-2010 | 10:08 PM
ARodvold's Avatar
But it looks so ugly =(
Old 09-22-2010 | 10:50 PM
Syldrin's Avatar
who cares how it looks when it goes fast.
Old 09-22-2010 | 10:54 PM
SoccerBoy_AP's Avatar
Show? or Go!
Old 09-22-2010 | 11:43 PM
Ace83's Avatar
Ronin Scion
it depends on which one you get, i think it looks cleaner than a rusty turbine housing unless you are ballin on an expensive turbo. It even helps to spooling in your turbo.
it helps tons keeping hood temps down
Old 09-23-2010 | 02:36 AM
x_Batman_x's Avatar
I love the way my blanket looks:
Old 09-23-2010 | 03:01 AM
Syldrin's Avatar
youre set up is clean batman
Old 09-23-2010 | 04:36 AM
GUNNIST14's Avatar
Like stated before by others you'll see quite a temp drop with it and spool up will increase because all the gases and heat are being kept in the exhaust stream so to speak. It won't lower your performance it will help it.
Old 09-23-2010 | 05:33 AM
05_ScionTC's Avatar
hey Batman, do you got a flexpipe on your setup? just wonderin since my S1 kit i bought doesnt got one on the s-pipe or downpipe..Just wonderin
Old 09-23-2010 | 05:37 AM
Murphys_Law's Avatar
thats a hot setup batman
Old 09-23-2010 | 05:51 AM
deez's Avatar
Looks awesome dude, Props.
Old 09-23-2010 | 06:21 AM
x_Batman_x's Avatar
thanks for the props guys :-)
and 05, no flexpipe came with kit and you dont need one but it is EXTREMELY important that you bolt the s-pipe to the mid-pipe using the springs 100% correctly. Double check the install guide when installing and call Dezod if you are at all confused.
Old 09-23-2010 | 10:22 PM
johnhawkins's Avatar
In general like mentioned above, it will help efficiency and performance. The turbo blanket will be good but if you use it on headers/manifold liek pictured above. It can/may lead to crack in your manifold.
Old 09-25-2010 | 07:46 AM
jsg93085's Avatar
is that manifold shroud custom made ace? also, which blanket do you have on the turbine?
Old 09-25-2010 | 02:15 PM
Ace83's Avatar
Ronin Scion
the manifold blanket is just generic blanket made by DEI that I cut and tied to the manifold.. i would say its not so bad to the manifold like those heat wraps used on manifold and downpipes.. The turbo blanket is one i got in ebay, its quality is pretty good.
like this but in chrome with inside seams
http://cgi.ebay.com/ebaymotors/T3-T4...#ht_5207wt_941
Old 09-26-2010 | 03:18 AM
Yea header wrap does some damage I deff think the stuff you got is much more effecient and will not damage the manifold over time like the wrap does sometime.
k1114
43
03-01-2023 04:08 AM
bigAL
03-19-2018 07:00 AM
xa007xa
02-22-2015 04:05 PM
rrtxdrvr
01-24-2015 04:08 AM
