Turbo Install Help
Originally Posted by tC_litigator
It sounds as if the ecu may be in the "safe mode" setting. You might want to consider that as well.
450 injectors.
You can use the stock injectors with the stock ECU at 3-4psi until you have engine management. The reason the car is dying is because you are hitting open loop and running extremely rich. Put the stock injectors back in and run very low boost to get going.
my06tc
06-25-2015 12:18 AM
ScionLife Editor
11-25-2014 03:00 PM
TheRedBox
31
12-02-2003 04:53 PM
