"Turbo Kit" BUILD **Updates PG40**
Old 11-06-2007, 03:10 AM
  #441
Music City Scions
j3st3r's Avatar
Originally Posted by mikescion
nah theres trannys holding alot of power.hmmmm could it be because theres No movement at all could that maybe cause the stress for it to then pop out
The Nitto/Jotech 739whp tC uses the same brace though.
j3st3r is offline
Old 11-06-2007, 03:26 AM
  #442
Mugetsu's Avatar
I'm a bit confused i thought you guys that run those crazy aluminum IM's did it cause...well cause crazy aluminum IM's are cool...
if those NITTO guys made 734hp on their "streetable"(whateverthatmaymean) TC using the stock IM.
i mean i'm sure their car is anything BUT a daily driver but what issues would you have around say 400hp?
Mugetsu is offline
Old 11-06-2007, 03:42 AM
  #443
Music City Scions
j3st3r's Avatar
The Nitto IM was not stock, this is the pictures of it as a matter of fact.....
http://www.jotechracing.com/projectc...ctVehicleID=55
j3st3r is offline
Old 11-06-2007, 05:02 AM
  #444
Mugetsu's Avatar
Ahh...i see, wow yeah i stand corrected
Mugetsu is offline
Old 11-06-2007, 02:20 PM
  #445
Music City Scions
rhythmnsmoke's Avatar
My boy B. Holding it down. Can't wait to see it back in person.
rhythmnsmoke is offline
Old 11-06-2007, 02:29 PM
  #446
cessblood's Avatar
Nice numbers
cessblood is offline
Old 11-06-2007, 02:31 PM
  #447
Enrique9876's Avatar
congrats! sounds like a great build... good luck with the tranny issues.
you made me a little nervous with the IM not holding more than 20psi for an extended period of time... i really have no plans on replacing it and am currently about to start my own build... yikes. but then again im only looking for 400.
Enrique9876 is offline
Old 11-06-2007, 04:21 PM
  #448
Complication's Avatar
now are you using the Hydra 2.6 software or the 2.5? I know they said that the update would be avialble around November...
Complication is offline
Old 11-06-2007, 04:29 PM
  #449
TCpete's Avatar
freaking HOT.. now thats how u do it... non sucka content in here...big props.
TCpete is offline
Old 11-06-2007, 05:41 PM
  #450
Music City Scions
j3st3r's Avatar
2.5
j3st3r is offline
Old 11-06-2007, 05:51 PM
  #451
yamaha16bw's Avatar
I dont think the 2.6 is out just yet. Hopefully soon, Ive heard good thing about it.
yamaha16bw is offline
Old 11-06-2007, 08:58 PM
  #452
etsnet's Avatar
What compression pistons are you running?
Congrats by the way. Glad to see things are almost done.
etsnet is offline
Old 11-07-2007, 03:04 AM
  #453
Music City Scions
j3st3r's Avatar
Compression is 8.5:1
j3st3r is offline
Old 11-07-2007, 03:08 AM
  #454
Whocares05050's Avatar
Way to go brian. Finally get to enjoy it!
Whocares05050 is offline
Old 11-07-2007, 03:22 AM
  #455
eov32885's Avatar
wow, that's just crazy, hope you break 500!
eov32885 is offline
Old 11-07-2007, 04:43 AM
  #456
Music City Scions
j3st3r's Avatar
Almost...not quite yet....got to get the freaking transmission figured out now....I can see why our crew calls my car the unicorn......LOL
j3st3r is offline
Old 11-07-2007, 09:46 AM
  #457
turbogsxr750's Avatar
i wasnt going to post in here but if these numbers are ture i have to. To all that questioned the use of a tubular manifold with a merge collector and a remote tube, this should put a rest to your doubts. I designed the manifold on this car and i knew what i was doing when i did it. I have tested many manifolds on a flow bench like this and i have seen no down sides to using this type of set up. that is exactly why every V8 car on the planet uses this same type of setup. Everyone on this board can say what they will, but i have tested many types of metal (mild steel to econel) and many types of gauges (.065 to .11 wall thickness. I have tested this exact type of setup (header with remote mount turbo) and i have made amazing results(1088 foot pounds of torque).
The problem with the companies on this site are the fact that the use only schedule 10 or 40 steam pipe and they belittle the companies that dont. They question the abilities of the compaines that dont use this type of pipe and turn it around to make themselves look better.
I am sure that i will in some way become the as$hole in this thread but i know more that anyone on this board on air, exhaust and fuel flow when it comes to manifold and exhaust design on a flow bench and what it really means on a dyno jet reguardless if it is a chassis or and engine dyno.
Let the flames begin.
Brad
turbogsxr750 is offline
Old 11-07-2007, 12:25 PM
  #458
Music City Scions
j3st3r's Avatar
Brad
Let me be the first to flame you................thanks for the manifold design man!!! The numbers are real, and the manifold DOES work. I have also seen this type of design work in the V8 world time and time again. So all I can really say to you is, nice work!
j3st3r is offline
Old 11-07-2007, 12:44 PM
  #459
mikescion's Avatar
good shyt i was wondering about it. but it kicks ___ lets seee some 10's lol
mikescion is offline
Old 11-07-2007, 01:16 PM
  #460
krazylowgsx's Avatar
____ brad, numbers dont lie.... Brian proofed that! awesome work guys! ican't wat til you dump the race gas in it and turn the boost up tp 30...
krazylowgsx is offline
Quick Reply: "Turbo Kit" BUILD **Updates PG40**
