"Turbo Kit" BUILD **Updates PG40**
#681
Music City Scions
Originally Posted by brett561tc
Originally Posted by j3st3r
Well unfortunately orings, sorry I was informed that these are actually called isolators, did not fix the problem, so now I am pretty sure its in the map. I changed plugs and did a compression test just to be sure. Cylinders all checked out fine, and the new plugs are in. Looks like I need to retune, and adjust the map......yippy
i dont know your exact fuel system set up off the top of my head brian. so i dont know if you have the same problem. but i dont see how it could be the hydra since the stock ecu no longer has the ability to control the fuel settings.
There is also no CEL, and I have cleared any OBDII codes that were in the ECU. I am pretty sure the problem is in the map......at least that is where I hope it lies. My concern with this whole incident however is if inconsistency is now going to be a common thing. I know it will change some depending on the weather, but I am not going to be happy having to live with a car that is fine one day, and then all of the sudden tune is off. Obviously if a situation arises, such as the isolaters/orings, then it will be addressed...but I really thought those would have fixed this issue/
#683
Music City Scions
Originally Posted by aen
how are you in wot?
#685
Music City Scions
Originally Posted by TRDChargedtC
Did not actually get to race this day, I had no tires/rims for it. Should get some race action at VIR, in October though!
Yes I am planning on being there.
#686
Just a couple of ideas i'm throwing out =D
Is the vacuum line to the hydra fine? No pinches? Leaks? Clogged?
Try changing the air temp/coolant trim maps to compensate for the changes in ambient temp? Don't think its this one though, unless it was a reallll drastic change in temps.
Intake manifold gasket? Probably not.....
Try recalibrating the hydra wideband??? After a few month of running rich, I was forced to recalibrate it, because it wasn't reading right at all.
Also, are you running the stock secondary 02 sensor?
If so, I wonder if it went bad, and you have the hydra closed loop setting to
LEFT MODULE SENSOR SOURCE:
14.7 LEFT U/HEGO
RIGHT MODULE SENSOR SOURCE:
14.7 LEFT U/HEGO
It might explain why you're running lean. Maybeeeeee.
I'm trying my bestttttttttt, lol.
14.7 LEFT U/HEGO
14.7 LEFT U/HEGO
#687
Music City Scions
14.7 LEFT U/HEGO
14.7 LEFT U/HEGO
14.7 LEFT U/HEGO
14.7 LEFT U/HEGO
#688
Hey I appreciate the help, I will take a look at some of those settings tomorrow, I wanted to take a better look at the line to the Hydra anyway since it was kind of done half butt the way they routed it through the firewall.
I believe in karma =) lol
BTW, I don't use a stock secondary 02 sensor, I have an Inovative Wideband in there instead.
So in the hydra closed loop settings,
I have it set to,
14.7 Wideband Hego
For Left and Right Sensor Sources.
Thats why I was wondering if you're still using the secondary 02 sensor ^^
#689
^^ hey im still using the 2 stock sensors but my initial setup was set to 14.7 WB Hego now i changed it to Left and Right 14.7 it didnt really make much difference.. I never had any idling issues, I simply changed the afrs values with ac on and ac off and everything is smooth.. the only thing that bothers me is that my maf sensor's AIT is reading very low
#690
So your hydra isn't trying to control the idle afr. I'm just theorizing (is that word? lol).
But hey it works for you.
I'm still struggling with mine. I was gonna try to do some playing around with it today, but a hurricane might be headed my way. So I had to setup the hurricane shutters on the exterior of the house.
Btw, what is your AIT temp? Maybe the temp is really low because your intercooler rocks =D
#691
Try recalibrating the hydra wideband??? After a few month of running rich, I was forced to recalibrate it, because it wasn't reading right at all.....
Pito
#693
Pito
#694
Pito
But the Temp Sensor I got with the hydra.
Is that what you mean???
#695
I have a an AIT sensor, that taps one of the wires (blue colored I thinked) on the maf (I cut this off, lol).
Pito
#696
Pito
The only difference that may be different is the Wideband, since early hydra users used a different brand. Thats not the case anymore though, since everyone is confined to the HydraWB. To bad we can't use bosch, since there so cheap >.<
But to answer your question of what kind of sensor the AIT is, i'm not exactly sure, sorry.
The sensor is attached to the chargepipe right before the throttle body. I'd say its about 6-8 inches away from the TB.
Sensor has 2 wires. One is grounded to the side of the cylinder head. The other taps into the blue wire off the maf.
When i'm in the hydra software, it tells me the intake temps, and its also very helpful, when i'm datalogging ^^
#697
#698
Lower rpm setting you mean the lower rpm closed loop setting? i cant remember exactly where but its set around 900- 1.1K rpms, closed or open hydra controls everything so im sure its controlled by the hydra as I can control my idle afrs easily by altering values about 6 cells in my fuel map at the idle area.. idle is smooth that made me pass tx inspection (no OBD), on the other hand im using a way smaller injectors than you guys which i think it close the preset setting from hydra.. there should be areas that might need to be set for you guys
On a side not, I spoke to the guys at hydraems, and I spoke to him about my problem. Basically he said, the hydra at the moment, does not fully control the idle.
The stock ecu is still somewhat in control of it.
In a later version of the hydra, he said that we'll be able to set the idle rpm to whatever rpm our heart desires =D
Im using my stock AIT sensor on my maf, i think its messed up.. and its still located on my intake so the IC has nothing to do my IC.. Once I get my hydra AIT, im gonna move it right before the TB.
#699
Music City Scions
