"Turbo Kit" BUILD **Updates PG40**
Old 08-22-2008, 02:28 AM
  #721
Ronin Scion
Ace83's Avatar
yup a zpi stage zero could dyno almost the same on a way smaller turbo, no intercooler, no engine management, stock injectors, 7psi lol.. but what im really interested is getting the hydra configured to make a very consistent tune, j3st3r's #s are pretty good all he has to do is smoothen out everything, and he if changes a lot of values on the boosted side, he might change his numbers
Ace83 is offline
Old 08-22-2008, 03:03 AM
  #722
coryjames's Avatar
i would be sad if i made 240 at 10psi on my kit i would cry plain and simple
coryjames is offline
Old 08-22-2008, 04:46 AM
  #723
Ronin Scion
Ace83's Avatar
^^ out kit is almost identical watch out haha.. no man, really its not the kit.. its either something wrong with the car or its really just the tune.. there's a really pig rich part on my tune when you slam on the throttle and to me thats gonna hurt the numbers, in fact i feel more pull doing part throttle
Ace83 is offline
Old 08-22-2008, 12:07 PM
  #724
B_Real45's Avatar
Ace,
Have you ever tried to do a compression test on your car? Make sure you're around 180-190psi per cylinder. And I'm sure you've checked for boost leaks and exhaust leaks before the turbo right??
B_Real45 is offline
Old 08-22-2008, 12:13 PM
  #725
Ronin Scion
Ace83's Avatar
compression is around 190s all 4,, no boost leaks and all are clamps are pretty tight.. exhaust leaks on the manifold is questionable though, im not running a gasket on the mani-turbo but i dunno if its gonna cause power loss that much
Ace83 is offline
  #726
Music City Scions
j3st3r's Avatar
Originally Posted by Ace83
J3st3r, we have the same tuner but didnt you upload and save your original map before you edited? i do think the guy can tune, i just dont get wtf is wrong with my car.. you are tuned 555hp but mine only got 230 hp/240 tq at 10 psi on a gt30 lol
but yeah my 1st gear is sluggish and goes too rich after 4.5K rpm, once i get my new laptop and gonna start on datalogging and see whats going on.. i've been changing my tune offline which is a pita.. my idle is fine and never stalls but i have some weird afrs issues that i blame on my wrong AIT readings, lol it never ends
I thought that I had saved that map, at least that is what I went in and did when I first got it, but not sure what has happened. When I open that map I saved the spark values are not the same as they were when I first got it, and I know I have not been making any changes to that. Usually I will upload the map from ECU, and then make some changes, however the ONLY changes I have made to the map were with the AC Step values, and the MIN ISC values to get the idle when the AC is on squared away. The only thing I can think that might have happened is that when I was running it once the car died, and the laptop battery was dead, so when the car shut off the laptop shut off, but....since I did not upload(download actually) anything to the ROM of the Hydra, the changes I made should have been lost because they were just in RAM. Like I said, at this point I just want to get the map he used to tune the car on, and go from there.
j3st3r is offline
Old 08-22-2008, 12:15 PM
  #727
B_Real45's Avatar
Exhaust leaks are devistating to power.. before turbo of course..
Why not just double check - remove the turbo, and use some hi-temp RTV sealant or buy a T3 foot gasket? It wouldn't hurt..
B_Real45 is offline
Old 08-22-2008, 12:16 PM
  #728
Ronin Scion
Ace83's Avatar
im pretty sure kenny still has your tune,..he should keep the tune since your number is good.. did you try calling or aim him?
Ace83 is offline
Old 08-22-2008, 12:21 PM
  #729
Music City Scions
j3st3r's Avatar
Man I have tried every which way you can think of.....hell I even tried Keisha....hell I still cant even get all my dyno charts from him, I keep hearing he has tons of them, and yet I have like 2.
j3st3r is offline
Old 08-22-2008, 08:57 PM
  #730
brett561tc's Avatar
if you ever get them, post them up. im curious to see the power curve by rpm insted of speed. would also like to see the torque it makes and when, and how well the port and polish of the head helps spool that big gtk. this is assuming you can get kenny to play ball, and we all know how that can be.
...by the way. any chance of cams in the near future?
brett561tc is offline
Old 08-22-2008, 11:02 PM
  #731
1CLNTC's Avatar
OMFG nice setup bro..
1CLNTC is offline
Old 08-22-2008, 11:04 PM
  #732
Music City Scions
j3st3r's Avatar
No cams in the near future, I want to get a consistent tune first on 15psi so when I do take it time attack racing, I am not having to play with it to much. I am working on the map right now to see what I can get worked out. Also when I pulled the injectors they are NOT 1400cc they are 1200cc, so not sure if I will try running the 1000cc or not.
I am as curious as you are on the torque curves, and I would like to have all of the dyno charts from my damn car, just to have them, good or bad
j3st3r is offline
Old 08-23-2008, 07:32 AM
  #733
etsnet's Avatar
Call his lawyer, that always seemed to work for me.lol
etsnet is offline
Old 08-23-2008, 02:46 PM
  #734
1UP Crew
ippskidder's Avatar
omg that so wrong paul, hahahhahahhaha.
ippskidder is offline
Old 10-01-2008, 02:19 PM
  #735
Music City Scions
j3st3r's Avatar
Just an FYI, all of my stuff is for sale now, after 2+ years of dealing with this, and the BS going to put tC back to stock motor wise.
j3st3r is offline
Old 10-01-2008, 02:28 PM
  #736
brett561tc's Avatar
Old 10-01-2008, 02:30 PM
  #737
mikescion's Avatar
wow. why?
mikescion is offline
Old 10-01-2008, 02:33 PM
  #738
SoFloTC's Avatar
is this serious? wtf?
SoFloTC is offline
Old 10-01-2008, 02:34 PM
  #739
Music City Scions
j3st3r's Avatar
Originally Posted by mikescion
wow. why?
2+ years without the car, and its STILL not tuned or running right.....I have lost all interest, and excitement over this. I need a car I can drive, not to mention I am the head of Music City Scions, and I am tired of not being able to participate with the crew.
This was a HUGE...very tough decision, but at this point , and I am sure those that know most of the story wondered why I did not do this earlier. Letting someone else work on my car was probably one of the biggest mistakes I have ever made, and if the past BS was different then probably would keep the setup, but....enough is enough.
The plan is to put a stock motor back in it, and maybe look at the Ptuning setup later down the line.
j3st3r is offline
Old 10-01-2008, 02:41 PM
  #740
SoFloTC's Avatar
i feel ya. theres no way i would have waited 2+ years. ive been out of action for only a month and sometimes i wonder wtf im doing.
im behind ur decision. ptuning street kit would be a nice bolt on alternative.
SoFloTC is offline
Quick Reply: "Turbo Kit" BUILD **Updates PG40**
