turbo kit question!! plz read
http://cgi.ebay.com/ebaymotors/JDMS-...Q5fAccessories
if i was to put this on my auto tc what would i be missing in this kit??
i would only run like 6 psi but how long do you think it will run without a tune?
if you were to put on that kit, you would be missing, a good blow off valve,good waste gate and a good turbo, injectors, engine management, intercooler piping that fits (you'll have to cut it) and maybe more.
and as far as it running without a tune... running a good kit without a tune isn't even good. this kit, it's hard to say what would go first. the engine or a piece of the kit. but it wouldn't be long
who do people constantly ask the same questions about boost?
"can i run it without tuning it"? - NO
"can i run it on stock injectors"? - NO
"will it blow my motor"? - YES
"will anything go wrong"? - YOU BET
"does auto matter?" - YES
https://www.scionlife.com/forums/sho...d.php?t=200808
https://www.scionlife.com/forums/sho...d.php?t=201427
https://www.scionlife.com/forums/sho...d.php?t=196353
https://www.scionlife.com/forums/sho...d.php?t=197970
https://www.scionlife.com/forums/sho...d.php?t=198653
dont ask anymore questions until you've read these threads. this is only like a few that ive came across in the last 4 months or so.
awesome kit, go with it. you should be able to run 12 psi w/o any management without any problems.
^agreed. no need to upgrade injectors, oem is about 330 which is more than what you need. /thread
Thanks guys for your help<- not. I'm sayin you got a car that is 400hp and you run it full 400hp all the time is gunna blow up sooner or later what if I'm only pushing a few pounds can it work? No sh.I.t if I was at 12 pounds I'd blow my motor first rev, I know the turbo is bad but what if I kept it under low stress
its all up to you man, honestly you looking for trouble from an ebay turbo kit.....just save your cash for one from dezod or descendent or even ptuning trust me it'll save you the heartbreak in the long run......oh and with the automatic make sure to get a tranny cooler unless you decide to go stick before you get the turbo kit
did u even read the threads i posted? cause it clearly seems like you can't read or something. were not gonna sit here and explain everything in detail why you cant run it....its been answered thousands of times. want your answer, read the damn threads
cessblood
09-15-2015 06:50 AM
DjFrOsT
11-12-2003 04:51 PM
