turbo maintenance
turbo maintenance
so i'm newly boosted and wanted to know just some daily/weekly maintenance things i should do...i installed this myself, so gettin dirty is not bad.....also, whats the amount of oil i should be putting in the engine (qts?).....any tips would be good! also, anybody take the stage 0, and run higher boost? and what electronic boost controller are you using? and lastly any upgrades i need to be running like 1-2 more psi? thanks everybody!
You don't need to, and should not, put any more oil in that regular factory specs. But, what you should do is change your oil more often, especially when its first boosted, think of it as a brand new engine, you have to break it in all over again, to get used to having boost. It'll be hard, but you should try to drive 500-1000mi w/o going above 0vac/boost to allow everything to mesh together (i'd assume you upgraded your clutch, fuel assy, etc). With my old cars, every time I boosted them, I would change the oil every every 500mi for the first 2 times, then every 1000mi for 3 more times, then i'd go back to 3000mi like normal, but take it easy for the first oil changes, make sure you check your oil levels often too, that last thing you need is to be short on oil in your boosted engine, not fun. As for a boost controller, depending on your budget, i'd say either a Greddy Profec-B (cheaper side of electronic boost controllers) or if you want bling and got the extra cash, you could get an Apexi AVCR (way over kill though). As far as 1-2 extra PSI, I don't know anything about tC motors, so I don't know what they can handle, that and I also dont know how much boost your running currently.
Also, if you havent upgraded your factory clutch assy, I would highly recommend it, the stock clutch prolly wont hold up too long to getting beat up with boost. That and you will notice a lot more power making it to the wheels with a better clutch (get a lighter flywheel while your at it). Having a turbo car is easy, just make sure you watch everything very closely, things can (but dont have to) break very quickly if you dont catch problems right away. Good luck!
Re: turbo maintenance
Change over to Synthetic if you haven't done so. Royal Purple is top of the line, that's what I'm running in my girls car now. As stated before, you will need to break in the motor with the turbo on it, so take it easy for some couple thousand miles, and then you can play around with it. I change our oil more frequently that I would normally, but other than that, I maintain it like it was factory. Nothing ABSOLUTELY extra HAS to be done to insure reliability beside frequent oil changes. You should see more PSI with a couple of other additions to the Stage 0 kit. For example, the following mods could possibly produce an extra PSI or two.
Intercooler upgrade
Methanol kit addition
Exhaust addition (if you don't already have one)
as well as adding the optional E-manage (as you can tune it to be a little less on the rich side, thus possibly creating an extra PSI of boost in the process).
I don't have a boost controller on our car, it's controlled via WG spring.
PS...the HKS turbo timer is a nice little unit. I do more with it besides just having it keep the car running an extra 30secs after I remove the key.
I do:
1/4 mile testing (w/ trap speed)
1/8th mile testing (w/ trap speed)
0-60
60 foot
And it can also act as a Shifting light.
Every Friday when I come home from work I check under the hood. I check piping, oil, oil leaks, vac lines, ect.. I do this to make sure everything is ok. I'm not sure if it's over kill but I'd rather stay on top of things. I also check everything after I've been hard on it too. I find it to be a good safe routine.
Originally Posted by xBtenchu
^^I just fill up the gas tank when the light comes on, and change my oil when the Maint Recq. light comes on...
I WANT THE TRUTH.....
YOU CAN'T HANDLE THE TRUTH!!!
The only time the hood opens on our car is
- change the oil
- change out the battery (for winter, need more CCA)
- show other people what makes it go
- remove the rain protector from under the CF hood.
Other than that, I'm being honest, I never pop the hood to check anything. If something happens THEN I pop the hood (Not saying that checking stuff is bad or anything), just saying what I do personally, which basically is ....nothing.
I really dont do maintenace to mine either. I just drive the hell out that _____, im on the phone with dezod and he is like chill out dude everytime i talk to u all i hear is wastegate. I drive it like a stole it.
kleecker
9
05-26-2015 12:12 AM
Sevedd
03-03-2004 08:28 PM
DjFrOsT
11-12-2003 04:51 PM
