Turbo PSI Question
Old 04-25-2010, 07:06 PM
athletefeet66's Avatar
yeah im running the greddy kit and i have the replacement manifold with support bars but the welds cracked on the support bars... :/ it has been holding up fine for now, we will see how it does with some more boost running through it. how much is that replacement manifold? i got mine used so it came with it. if mine cracks im going to go custom with EWG.
i have 550cc that im going to install once i get tuned for 10psi and see where that takes me.
athletefeet66 is offline
Old 04-25-2010, 07:29 PM
RichTc's Avatar
Well if my injectors are tapped out, that's fine, I don't need really need to go any higher. I'm too the point where I have enough power to keep me happy and don't want to drop more money than I need to into the car.
Greddy couldn't give me a price on it as they don't sell it directly, but they said 400-500. I was looking into another manifold, but am unsure what will fit. From what it seems, it may be more than it's worth to make something fit, considering modifications to the down-pipe and intercooler piping that might be needed.
RichTc is offline
Old 04-25-2010, 07:38 PM
m6ar2cel6oTC's Avatar
Default Re: Turbo PSI Question
Originally Posted by jsmillie07
I've heard of ppl not being able to hit 300 with 550s and even 630s. It really depends on your tuner. I'm going to assume with ptuning that 550s are too small. Just contact them and get their opinion.
Heard wrong I made 326whp on my old 550cc And they weren't maxee out.
m6ar2cel6oTC is offline
Old 04-25-2010, 07:39 PM
Originally Posted by coryjames
boost dosent mater like you would think its about temp i make massive power for my boost level thanks to angry timing and e85 my turbo makes cooler air at higher boost more efficiency ask gingles its all about tune and temp i have seen cars with alot of boost but no power due to rich tune and conserv timing.
How are you monitoring timing? Knock?
Old 04-25-2010, 08:36 PM
coryjames's Avatar
who gives lol i dont monitor knock lol if it blows it blows why play it safe motors are cheap and the fun intense lol ................ no i have ways lol im rocking alot of injector got 900s twin pumps and 70 psi of fuel pressure
coryjames is offline
Old 04-25-2010, 08:44 PM
If you say so baller lol. Raise the boost more and see how much heat the cylinder walls can take lol.
Old 04-25-2010, 08:47 PM
ecko04's Avatar
...I'm going to assume with ptuning that 550s are too small. Just contact them and get their opinion.
Incorrect, PTUNING includes 550cc with their turbo system, which is capable of making 300whp with the default setup.
ecko04 is offline
Old 04-25-2010, 09:03 PM
jsmillie07's Avatar
That's why i said to contact them to see what they think. I know it really depends on the tuner.
jsmillie07 is offline
Old 04-25-2010, 09:10 PM
coryjames's Avatar
i run 12-12.5 afrs pull no timming till 8 psi then pull a half degree a psi past that
Old 04-25-2010, 09:16 PM
gingles's Avatar
timing? whats that? e85 says screw timing i want more.
gingles is offline
Old 04-25-2010, 09:20 PM
coryjames's Avatar
yes e85 is like a sorority girl on spring break more more and then some more
Old 04-25-2010, 09:37 PM
ecko04's Avatar
Actually it doesn't. Reputable tuners do not tune for power, if a tuner ever tunes for power that's a huge problem. Most tuners won't even say "sure your car can get xxx whp", they'll say "we'll see when we get it on the dyno", tuners are less worried about power and more worried about reliability so you don't hop out there and throw a rod through the hood.
ecko04 is offline
Old 04-25-2010, 09:52 PM
jsmillie07's Avatar
I agree with you that using a tuner that just tunes for power is bad, that's the reason why I won't take my car to CFT. Just some tuners are a little more conservative then others. Based on their experience and how they tune they might tell you that you need bigger injectors or more psi if you want to hit a certain power range.
Old 04-25-2010, 10:42 PM
ecko04's Avatar
Agreed
ecko04 is offline
Old 04-25-2010, 10:49 PM
That's exactly my theory but no e85 for ne just meth.
Old 05-05-2010, 03:41 AM
Joselo's Avatar
Hey Guys I'm new to the F/I forums and was wondering (sorry if its a bit of threadjacking) if I need to worry about anything If Im using a Greddy Kit + 550 Inj, because I want to run at 10 or 12 psi but I don't know if that would be "safe" any help guys?
Joselo is offline
Old 05-05-2010, 11:44 AM
3min3m2's Avatar
With boost, safe is an arbitrary term applied to set-ups that have yet to destroy motors. 10-12 psi is not in that category generally(IMO)
but if u have a good tuner and clutch, have fun.
3min3m2 is offline
Old 05-05-2010, 01:39 PM
RichTc's Avatar
I run 10psi on my greddy kit (with 550s) and haven't had any problems. Agree with the poster above, that it is all in the tune.
RichTc is offline
Old 05-05-2010, 01:48 PM
Music City Scions
rhythmnsmoke's Avatar
Originally Posted by RichTc
It's kinda funny, people make such a big deal about buying the "most powerful kit" as most will never realize the full potential of their kit (as most do not build their motor, from what I can gather).
It would seem to me that if your not planning to build out your motor, you should just buy the cheapest kit you can find (as your motor will most likely limit you before your kit does).
Would have to disagree with that. More and more people are building their motors these days than when F/I first started with the tC. The people who don't build their motor, usually don't buy the most power/potential kit.
And for those that do and don't build, it's like that old saying...."I'd rather have it and not need it, then to need it and not have it".
Boost is addictive and once you start turning the BC up, you never want to go back down or stop for that matter.
rhythmnsmoke is offline
Old 05-05-2010, 05:10 PM
Default Turbo PSI Question
X1,000,000!!!
Quick Reply: Turbo PSI Question
