Turbo Specialties kit?
Is this a mistake, or does Turbo Specialties actually make a tC kit now?
http://www.sfxperformance.com/parts/TUSTS2503E.htm
The price seems way too good to be true, unless they're cheaping out on parts. Still, if they do make one...
Pray and hope they do not. They make a kit for the Civic 01-05, and it is garbage. Piping doesn't fit, management is garbage, 1st and 2nd gear are great, but nothing on 3rd-5th......We dominate that market~!
Oh boy. Yeah I installed one kit on a Protoge. Wow, was it cheap. The piping was nowhere near close to fitting. THey basically gave us a box of pipes and say here try this. I called them and had them send more piping to make it work. I had to weld up a few pieces to make it fit and cut the sheetmetal in parts to make it work. The turbo actuator was wasted out of the box, the BOV was a joke, and well the intake was a snorkel that looked like a part for a pool or something. Overall it was horrific. You're better off making something yourself than one of their kits.
Team No Limitz
yea, the parts are absolute junk. I ran the TSI kit on my xB about 3 years ago when there were no other turbo options. Their fuel management is a joke( 2 additional boss injectors unreliably spraying fuel into the throttle body, not individual cylinders so trying to dial in a perfect a/f ratio is pretty much non existant. On to the piping, all I can do is laugh about that The intercooler piping layout was a complete joke, and my father and I actually re routed all the piping and eliminated about a foot and a half of piping from the setup. Maybe turbo specialties should hire me for their intercooler setup because obviously they dont have the knowledge to properly route their piping setup. Basically, the only thing I used from that kit was the manifold, turbo, and intercooler. I pieced together my own fuel setup...converted to a return line, upgraded fuel pump/fuel rail, and used celica injectors instead of the injector boss that came with the kit. I would highly suggest against this kit as the components look like they were pieced together in someones garage, and Im pretty confident that I coulda put together a better kit. The only good thing is they use garrett turbo's and are not only oil, but also water cooled.
http://www.sfxperformance.com/common/Image-Popup.asp?ProductCode=TUSTS2503E&image=0[/img]
[ Turbo Specialties Parts ]
Size
W/T25 TURBO
Fitment Guide
Scion Tc 2.4l
Description
Turbo Specialties TS2503E
Extreme Performance Turbo Package -
If you are looking for the ultimate in high performance - the extreme performance packages are for you. Providing the maximum horsepower for the very discriminating and still providing dependability for daily driving. Incorporating all the high performance equipment in the superior performance packages, these extreme packages all include an intercooler pop off valve, extra injectors, and injection control unit, (The Brain). This offers complete control for your system, increased fuel delivery, and cooler temperature gas air mixture for better burning. The addtion of this system can add as much as an additional 20 percent increase in horsepower above and beyond the superior turbo packages.
Misuse or improper installation of some items may result in engine failure or possible bodily injury.
Kit includes:
1 - Garrett turbo with cast iron manifold and wastegate
1 - Down Pipe with gasket
1 - Injection Control Unit
1 - Injector interface block with injectors
1 - Blow Off Valve
1 - Fuel pressure regulator
1 - High flow intercooler with all mounting hardware, pressure tubes, rubber hose connections and clamps.
1 - Map Unit (Black Box)
1 - Oil return line and fitting
1 - Air cleaner with piping
All necessary hardware, lines, hoses, clamps and rubber connections needed for installation of turbo kit included for all items listed. Manifolds come with a five year warranty, one year on the accessories and Garrett covers the turbo itself.
Installation instructions included with each turbo kit and recomended injection control system settings included.
Legal for use in California ONLY for off road vehicles or racing applications.
Pictured is example only
Size
W/T25 TURBO
Fitment Guide
Scion Tc 2.4l
Description
Kit includes:
1 - Blow Off Valve
Team No Limitz
im confused as to why this kit is even being discussed...they are using the same turbo that is in the xB kit...isnt that enough to discourage some people? The only thing worth while about the kit is the fact that its a genuine Garrett turbo
cessblood
09-15-2015 06:50 AM
my06tc
06-25-2015 12:18 AM
2004, civic, extreme, intercooler, kit, routing, scion, specialities, specialties, t25, tc, ts2503e, tsi, turbo, xb
