Turbo Tc Down Need Help ASAP!
Ok so i have a ZPI Stage 1 turbo kit im running rc 550cc injectors and am tuned on 10psi using F/IC. Well the car idles real lean at 17 most of the time n sometimes even goes blank n stalls alot as well. even when u go to give it any type of gas the car still remains lean never going past 15.2 from what i have seen but it never stays there it always goes to 17 or blank. There are no vac nor boost leaks anywhere or exhaust leaks either i did a boost leak test n nothing came from it...i did have an hks that was leaking so i went n replaced it with a brand new hks and the problem continues even though it was leaking b4 n now the new one doesnt. This car is my daily so i need to figure out what is causing this so the issue can be resolved please please please HELP! (No i am not driving the car like this btw)
i have codes in which i checked the other day b4 it went down n they were for bad gas cap, secondary o2, n crank n cam positioning i dont have an odb2 code reader on me if not i would reread them now, no i dont know the fuel trims but mike tuned me n they were great when i got tuned soooo idk i jus wanna figure this out so i can get the car back up running
I would contact mike since he tuned you, he will know more about your setup than others here and should be able to point you in the right direction.
did you do anything about the cam/crank code?
i jus texted mike now but u know he is very busy with work and stuff so thats y i went here to look for answers n mike jus asked me and i quote "wtf reset ecu?" soo idk i texted him back saying i have not messed with anything at all in regard to the ecu,battery,f/ic prior to this happeneing i did unplug the f/ic box from the harness n it was the same way
as far as the codes no they have always been there since like a week after i got tuned n the car runs wonderful have had no issues dealing witht that code
i have seen with the cam/crank code you wont notice much till you get around 5,800-6,000 RPM's and you will notice a slight surging. you can see it on a datalog.
or this could be a cam sensor (i mean faulty sensor) issue maybe but i have yet to see this happen. I dont doubt it could happen though, just saying i havnt witnessed this yet.
how old is your primary o2 sensor?
i did what justin said n reset my fuel trims n the car is up and running great for now thank u very much to all who helped
lol +1 in 06 when my buddy had his turbo tc we would spend 20 minutes street tuning have it run awesome at wot and then drive it for the rest of the night only to have the weather slightly change and the car would correct everything we ever did the next day.
But more on topic, you speak of things that we often ran into with the car trying to change what the piggyback controller changed
Scionxa180
09-24-2015 03:51 AM
