Turbo TC from PR Dyno pull [email]356whp@16psi...video..link[/email] fixed
#43
The car will die if you let off the gas after build boost real quick ???
Tuner is just worried the car wont idle with that big of injectors....
How much did ur injectors run you, and about what level of power do they max out at.
#44
Your revs will go down almost to 400 and them they will start jumping between 500-1100 for a few seconds and everything goes back to normal soon after. It's not easy to control them with the e-manage but it's works at least until you buy something better. You could still buy a Hydra ems if you can't control them with the Greddy but I preffer to wait for Aem.Those injectors should hold all the power that you may squeeze from the TC engine.
#49
If you're building the engine you may want to look into these https://www.scionlife.com/forums/vie...550&highlight=
#55
All the time I worked on the car the last couple of times was to make sure the engine doesn't blow up (at least not by my fault )while upping the boost.
Tuner is just worried the car wont idle with that big of injectors.....
750 cc injectors running a fuel return setup should be capable of feeding a little bit over 500hp!!!
Pito
my06tc
06-25-2015 12:18 AM
JM Auto Racing
12-19-2014 06:36 PM
