turbo tC smells like fuel inside
so i installed 550cc deatschwerks injectors and a 255 walboro fuel pump and one day when i started up my car, a huge smell of fuel was leaking into the cabin. i removed my fuel rail to see if the injected were out of place and when i slowly unscrewed the fuel rail, fuel squirted out of the first injector. i thought it was just cause the injectors werent pushed in far enough so i screwed it in tighter, but still, the smell of gas leaks into the cabin... any ideas? do i need a new fuel rail? or any suggestions on a fuel regulator?
usually leaking injectors are pretty easy to spot, and dangerous.
but im leaning more towards the fact you may have a tank issue after installing the wallbro. check your lines to the tank and make sure its sealed properly.
it may be coming up through the access hatch after the pump starts cycling.
agree
And you probably can't smell a damn thing inside the engine bay, right?
I had the exact same thing. I never found out what it was, I just left re-circ on 100% of the time. I figured it was an exhaust leak, and I did have a minor leak on my manifold. :shrug:
Oh, and it's not the fuel pump.
Music City Scions
Did you drop the tank when you put the new pump in? I know on mine the vapor line was off on the side of the tank and the gas smell was horrible, once that was put back on, took care of it
