View Poll Results: CAI on turbo inlet
Voters: 21. You may not vote on this poll
Turbo Tc Topeka Style
I have that setup for sometime, i did thorough comparison on it..
here's what I find out..
1. not much benefit from it, the long pipes and bends reduces air flow as compressor sucks air.. not by much compared to regular short ram intake pipe but a considerable amount compared to intake pipeless turbo setup..
2. Difference in intake temp improves but doesnt stay that way very long.. as you use the car longer, the entire pipe would heat up too so after time it would be the same inlet temps as the short ram style setup
I also noticed you have smaller intake pipe near the compressor so more restrictions right there.. with a shorter pipe CAI it might work..
i did not do a before and after dyno.. i did dyno with it and i dont see any huge lag on the powerband and i do notice a little lag when i first installed it, its something you wouldnt notice after few days.. but after i removed the spool was faster, im not sure if its just the sound that made me say that but yeah an intakeless turbo is way better
ok so because p tuning does it, that doesnt mean its the best thing to do? and ptunings is ALOT shorter than that going a different route i believe. spool is quicker the shorter you go, honestly put the filter on the turbo and do a blowby setup..
Originally Posted by crush02342002
Originally Posted by SoFloTC
ew
Not even close though to this. PTuning's intake is STRAIGHT, with a direct flow from the outside and it's positioned below the engine thus more effectively producing colder temps than this setup I would imagine.
Okay, I thought I'd chime in here since several posts point to our intake design.
As some have pointed out, our intake tube is 4" in diameter and makes a very short and straight shot to the compressor inlet. As a matter of fact, you can probably stick your hand through the intake tube to spin the compressor blade.
IMO, the length and diameter used for your CAI will more than likely negate any of the benefits of a CAI filter location. Think drinking a milkshake through s soda straw.
With that said though, I do have to say that you did a good job with making your set-up look clean. Good luck with your build.
- Toan
- Toan
yeah it looks like you have a 2.5" intake right after the compressor inlet, i used full 3" pipe a noticed a bit of lag.. you might feel the restrictions even more.. but if you wanna stay with that setup, its not a problem, you're not gonna lose tons of HP
ew
ew
I wasn't ...... It's just that when you read the description of Ptuning's intake about it being straight, less curves being a direct flow to the compressor...etc, couldn't help but to think this guys setup is not as efficient. To many bends and length of the tube.
