Turbo Toyotas: Jacksonville Style!
Old 01-07-2008, 11:38 PM
  #261
java09's Avatar
yeah! and tell them java09 and davedavetC fixed you shiiiieettt!
java09 is offline
Old 01-07-2008, 11:56 PM
  #262
jaxtcracer's Avatar
haha guys... if this is seriously the problem... i will laugh in my own face, too. i really really really hope it is. but brandon, how long could i keep the zipties there? seems like the MAF could fall off at any time haha
jaxtcracer is offline
Old 01-08-2008, 12:06 AM
  #263
java09's Avatar
i zip tied mine on good i actually have pics of it on phils thread!! try dig through a little bit and you'll see how i had it on there! mine stayed on strong for two weeks with no cel!
java09 is offline
Old 01-08-2008, 12:17 AM
  #264
java09's Avatar
matt had to zip tie his too!
java09 is offline
Old 01-08-2008, 12:34 AM
  #265
t_urbo_C_harged's Avatar
get the spare keys and steal your car from the lot hahah... I hope switching it works, although the 8 ignition coil codes doesn't sound good... did you have them clear those codes and see if they came back??? and yes you will need to check your plugs even still... if for some reason your ignition system wasn't firing because of the backwards maf, then your plugs could be fouled from all of the fuel dumping into the cylinders... also I don't see why the dealer can't fix it, the 4 basic principles of fixing a no start issue or drivability concern.
1. Does it have spark
2. Does it have fuel
3. Does it have compression
4. Is timing correct
What does a turbo have anything to do with what I have listed?!?!
t_urbo_C_harged is offline
Old 01-08-2008, 12:37 AM
  #266
java09's Avatar
yeah that dealership sounds retarted! haha
java09 is offline
Old 01-08-2008, 01:06 AM
  #267
jaxtcracer's Avatar
yeah we cleared the codes and they came back.. we never got a MAF code. a decent amount of fuel has been dumped into the cylinders, so it wouldn't surprise me if the plugs are fouled already.
Old 01-08-2008, 01:52 AM
  #268
jaxtcracer's Avatar
i'm just hoping the backwards MAF, fouled plugs, or something other than a bad ignition system can cause those coil codes
Old 01-08-2008, 01:56 AM
  #269
java09's Avatar
im not sure about that but im think the maf sensor will fix your problem.
java09 is offline
Old 01-08-2008, 03:39 AM
  #270
davedavetC's Avatar
i hope so for your sake man, i want the car running now, im starting to feel bad for you
davedavetC is offline
Old 01-08-2008, 03:40 AM
  #271
do you know what the codes are? if it is due to the cut harness, someone is going to be paying for the messed up ignition coils, not you...
Old 01-08-2008, 03:41 AM
  #272
java09's Avatar
thats fo sho!
java09 is offline
Old 01-08-2008, 12:29 PM
  #273
jaxtcracer's Avatar
i'll find out what the codes are today if the MAF sensor doesn't fix the problem. i talked to my service rep this morning and he said that if i come by the dealership after my classes (around 4:30ish) he'll let me go in the garage with my car and one of the master techs to try the MAF thing and various other small things. i'm sure we'll be looking at the codes if the problem persists, so i'll get the numbers for you if it comes to that. also, i don't know for sure what the performance shop did or did not cut; i'm waiting to pass judgement on that until later today when i can actually see it for myself. but yeah, if they did cut something that damaged coils or w/e else, there's a 0 percent chance that i will be satisfied with paying for it myself.
Old 01-08-2008, 02:30 PM
  #274
jrodTc's Avatar
Bro,
The backwards MAF IS your issue! Here's whats happening. The MAF is what the car reads to deliver fuel. With it on backwards, the reading is being thrown off while the larger injectors are still delivering fuel. So you have an extrememely rich condition in the combustion chamber causing you to throw coil codes. The coils are unable to cause combution. If you didn't know, its not fuel that burns, but its the fuel vapors that burn. When I had a coupler come off a charge pipe, my car appeared to have died! I was throwing 12 codes with all sorts of problems. I thought for sure I blew something. Turns out it was just a charge pipe. Fix that MAF issue and maybe put in a set of new plugs, and I bet your issues will be gone. As Dave said earlier, its probably something easy and dumb. LOL! Damn I'm sure thats it! Well I hope so!!!
jrodTc is offline
Old 01-08-2008, 02:40 PM
  #275
jaxtcracer's Avatar
ahhh my hopes are so high right now haha.. 3 hours of work followed by an hour and fifteen minutes of college before i can potentially be the happiest tC driver in the world!
in regards to the spark plugs: i know one of the techs looked at them yesterday, but i haven't talked to him to see whether or not they were fouled; hopefully not, but hey if all i need is new spark plugs and some zip ties for the MAF to be boosted, i'm all for it. believe me guys.. i will be posting later this afternoon when i get home from the dealership. it's either going to be a really joyous and fanatical post or a frustrated blab haha
Old 01-08-2008, 03:06 PM
  #276
07tctul's Avatar
good luck
07tctul is offline
Old 01-08-2008, 03:33 PM
  #277
jrodTc's Avatar
The Zipties should only be a short-time solution. You need that MAF to be installed properly, or you will encounter problems. Like the other TT users, make sure they send you a new intake pipe with the MAF adapter on the correct way. My fingers are crossed for ya buddy
jrodTc is offline
Old 01-08-2008, 04:11 PM
  #278
Mr_Meaty's Avatar
Damn...I thought I had mentioned to you about the maf sensor before? It must have been java that I said it to.
Yeah, mine was backwards...we dremmeled off the nubs and zip tied it on and it helf for a good 2 weeks till I got the new intake pipe from Todd.
When I had a bad map, I would throw 6 different codes all realating to differnt parts becuase that is what the car thinks is the issue. It does not know the f/IC is there controller fuel, so when I got a good map (in your case, got the maf right) none of the codes came back.
Damn, i'm starting ot get excited to! I'll look for a pic.
Mr_Meaty is offline
Old 01-08-2008, 04:17 PM
  #279
Mr_Meaty's Avatar
I can't beleive you told him to try and look through my thread for a pic!
anyway, here is a pic of what it should look like if the MAF is on CORRECTLY:
Mr_Meaty is offline
Old 01-08-2008, 06:15 PM
  #280
java09's Avatar
haha phil! dont hate because i officially fixed his car and hes going to buy me cookies!! i told him dig through yours because i posted pics of mine when it was zip tied on! then he could get an idea of how to do it! haha but yeah bad idea you cant find ishhh in this thread anymore!
java09 is offline
Quick Reply: Turbo Toyotas: Jacksonville Style!
