Turbonetic kit engine stalling, anyone else beside me?
Old 06-26-2006, 08:13 AM
  #121
redhorn's Avatar
Default random misfire
yes, same here. i installed the kit 3 weeks ago. ECL came on,and the codes read
P 0172 System too rich (Bank 1)
P 0300 Random misfire
P 0301
P 0302
P 0303
P 0304 301-304 Misfire cylinder #1to #4
Changed new plugs to BKR7EIX-11 ,gapped .044 or didnt gapped still having the same problem.
redhorn is offline
Old 06-26-2006, 12:29 PM
  #122
ELNENE's Avatar
so who here has not have a problem with the tns kit; other than munch?
ELNENE is offline
Old 06-26-2006, 01:05 PM
  #123
Munch's Avatar
Default Re: random misfire
P 0301
P 0302
P 0303
Looks like you might have messed up when you spliced the injecter wires. I would double check those first.
Munch is offline
Old 06-26-2006, 01:06 PM
  #124
Munch's Avatar
If it's installed correctly, there will be no problems. Every problem so far has been install error everytime
Munch is offline
Old 06-26-2006, 02:17 PM
  #125
MIAPLAYA's Avatar
I agree...check the injector woring and check the coil pack connections...
MIAPLAYA is offline
Old 06-26-2006, 04:24 PM
  #126
Schuller's Avatar
You need to bolt this on asap. Keep drillin. My bracket did not line up but I drilled it out and bolted it on.
Otherwise my kit runs great.
Schuller is offline
Old 06-28-2006, 02:29 AM
  #127
den_d's Avatar
My car also read all those misfire codes 300-305 and 171...i found out that one of my intercooling pipes came loose and i wasnt getting enough air. I reconnected it and now the OBD is only reading 171 and 300...I saw that some one said code 171( too rich) is supposed to be normal on the kit for safety reasons, but what about code 300(random missfire)? any one have any ideas?
den_d is offline
Old 06-28-2006, 02:52 AM
  #128
MIAPLAYA's Avatar
Please make sure your BOV fitting is connected to the correct spot as well. This seems to be a common trip up during installation/
MIAPLAYA is offline
Miqmiqmiq
04-16-2016 02:34 AM
oxxomxxo
01-26-2015 08:23 PM
Ramroids55
01-16-2015 02:42 PM
TheTripleC
01-04-2015 06:46 PM
Quick Reply: Turbonetic kit engine stalling, anyone else beside me?
