turbonetics CEL came on, scanned code...
I have a turbonetics turbo and my CEL finally came on after 2 weeks since the install. I had it scanned for trouble codes and found... "P2195 O2 Sensor signal stuck lean - bank 1 sensor 1" --> does this mean that im running lean?? all this time i thought that i was running rich, cuz it backfires once in a while when shifting gears. Anyways, i have the secondary O2 sensor extender installed, so i dont know whats wrong. vacuum hoses was checked all good. Do you guys think i need another extender or antifouler on the primary O2 sensor?? I tried to reset the ECU, but the CEL came on again after about 5 minutes of driving.
MIAPLAYA i also PM'ed you this issue. Thanks for all the help.
Stuck lean/rich usually means that the o2 sensor is not working. The ecu tries to change the amount of fuel to the car but the o2 sensor is not changing so in your case it is probably adding more and more fuel because it can not make the o2 sensor back to 14.7 afr.
Originally Posted by MIAPLAYA
No do not put an O2 extender on the primary O2. Whats your vacuum reading at idle? Have you checked your AFR yet?
MIAPLAYA, you said that it shouldn't be reading 8psi at idle?? where did you guys connect or tapped the hose line for the boost gauge?? I connected mines in between where the BOV port is and the T-fitting hose--> is this where its supposed to be or in between the wastegate port and the compressor port hose?? thanks.
Stuck lean does not necessarilly mean the 02 is bad. I have seen many more in that case that actually had an AFR issue rather than a bad 02 sensor. If the car cannot correct the lean condition within its set parameters (in other words, it is adding all the fuel it can and still reads lean) it will set that code. Check all of the things MIAPLAYA says and make sure all is connected correctly. I would then use a diagnostic tool to monitor the patterns on both 02 sensors to see what is really going on.
ill check for any leaks tomorrow and wirings, ive been coming home late. thanks for all the help...any more advice, just throw it in.
Correct below the 0 is vacuum. If you are only showing 8 below the zero something is wrong. Your car should read 20-22 below the 0. You most likely have a vacuum leak somewhere..
Hmm thats interesting. I've never heard of any company using BAR to measure vacuum. Even Japanese companies that use BAR for positive pressure use in/hg or kPa to measure vacuum. That reading is still a little off but certainly withing the acceptable range. I would still look around for a boost leak somewhere. Also verify your BOV fitting is on there correctly. Should be going to the port closest to the logo on the top of the BOV. Also would like to know what fuel pressure you are seeing. Do you have a wideband in the car? If so what are your idle AFR readings?
