Turbonetics Dyno
Turbonetics Dyno
I went to have my turbonetics kit installed yesterday. It was very consistent on each pull and running very healthy at stock wastegate boost. A/F was in the tens until about 5,000 rpms where it started to lean out abit and just hit low 11's.
Sorry for the lousy cell phone picks, I'll scan it when I get a chance.
Anyways, I received an RMA from Unichip to send it back to them because there was a problem uploading maps. I figure I'll go back in spring with a new clutch and more boost. I also want to add water/alc. injection before then.
8PSI from my guage. It's whatever the wastgate spring holds.
Also, this is with the stock S-pipe, Megan drift spec with a cat and resonator welded in. It's really quiet and that's probably causing me to lose about 10hp.
Originally Posted by Enrique9876
ps the s-pipe is the most restrictive part of the entire exhaust system .. let me be the first to DEMAND you upgrade that ;)
Just a follow up FYI.
I spoke with Unichip and the reason that my car could not be tuned is that Turbonetics has locked the map. So, in order to tune, they have to erase the map completely and start over with a fresh new map.
GRD told me that is what they had to do to tune IgnitionR34's car.
^^ yes this is exactly what they had to do. My unichip didn't have the up to date firmware. So they had to upload that in my computer, then they tuned it. I was at GRD basically for a loong as time, but they only charged me for 1 hour for the tune cuz thas how long the tunning took.
p.s. waht does rma mean??
