Turbonetics kit on E85 w/ Hydra EMS
Old 09-28-2009 | 12:14 AM
bsp_tc_06's Avatar
Default Turbonetics kit on E85 w/ Hydra EMS
Bone stock dyno pull
@ 6,000rpm = 151 HP
11.5psi @ 6,000 rpm = 308 HP
Thanks to Jeremy and Mike at Sublime Speed Technology for installing everything and tuning.
Here is a link to the custom 3" exhaust they made for me too.
https://www.scionlife.com/forums/sho...86#post3313186
Videos are in the works!
Old 09-28-2009 | 12:18 AM
weezyfbayba's Avatar
very nice! like that exhaust also
Old 09-28-2009 | 12:36 AM
B_Real45's Avatar
Very nice setup.. I think you should get more power on E85 though. Are you maxing out the injectors?
Old 09-28-2009 | 01:14 AM
m6ar2cel6oTC's Avatar
they probably took out to much timing. you can run more timing with e85! plus it is a mustang dyno so on a dynojet you will make a lil more power.
Old 09-28-2009 | 01:24 AM
crush02342002's Avatar
love how clean the whole thing is and a before and after dyno....mad props bro.
funny thing is i dyno'd almost exactly the same while stock (i mean before turbo dyno sheet) on a dyna pack dyno.
Old 09-28-2009 | 02:40 AM
coryjames's Avatar
yeah on boost levels like that you should make higher numbers i make well over that on a 8ps spring you probably have alot of timing pulled so who knows welcome to the e85 cllub what size injectors you running and your fuel setup
Old 09-28-2009 | 02:26 PM
Ace83's Avatar
Ronin Scion
there is no pulling of timing on the hydra its all advance unless you are using someone elses basemap, you will only go up until you need to stop.. I think you may need to go up some more. What is the ignition timing at 11 psi?
Old 09-29-2009 | 02:05 AM
KCTTC's Avatar
What are you comparing his setup to? He is running 700cc injectors and a walbro 255.
-Jeremy
Old 09-29-2009 | 03:15 AM
Ace83's Avatar
Ronin Scion
^^ comparing to his, he's on e85
Old 09-29-2009 | 03:26 AM
rhythmnsmoke's Avatar
Music City Scions
Very nice setup. A+
Is there any specific requirement to run e85?
Old 09-29-2009 | 04:12 AM
KCTTC's Avatar
He's not running a turbonetics kit.
-Jeremy
Old 09-29-2009 | 04:21 AM
Ace83's Avatar
Ronin Scion
ya I know but he can still compare. He is just using his setup as reference not saying he has to make exact numbers. The numbers is good but w/ e85 he can get more out of it.. but yeah im sure thats a good conservative tune
Old 09-29-2009 | 04:27 AM
gingles's Avatar
hes running a turbotoyotas kit with a gt30...still you should atleast see about 350 hp i think....well i guess maybe not...depends on your turbo size. and travis....e85 youll need atleast 1000cc injectors for 450-500hp, i suggest a full fuel setup, walbro or two, regulator, rail, lines, etc.
Old 09-29-2009 | 04:52 AM
KCTTC's Avatar
I understand. He stated that "on boost levels like that you should make higher numbers i make well over that on a 8ps spring you probably have alot of timing pulled". There is not much to compare other than the fact that they both run E85! I'm not trying to start an argument but clear up a huge misconception here on scion life. There is more to #s than just boost level and fuel type!
-Jeremy
Old 09-29-2009 | 05:04 AM
rangerryda's Avatar
Do you know what they used to cap the intake port to avoid recirc on the intake pipe? It's been something I've been debating but haven't bothered to search around the garage to cover it. Nice numbers!
Old 09-29-2009 | 05:28 AM
KCTTC's Avatar
It's a cap from a HKS BOV kit. Sorry I can't help more it was just something we had laying around the shop.
-Jeremy
Old 09-29-2009 | 06:16 AM
rangerryda's Avatar
Hmm, maybe I can scrap one up somewhere. I know a few people near me with HKS BOV's. Thanks for the input!
Old 09-29-2009 | 06:32 AM
memback's Avatar
Nice work how much did the exhaust cost? I like it alot its gorgeous.
Old 09-29-2009 | 02:54 PM
KCTTC's Avatar
S-pipe = $394.99
Cat back = $1094.99
Thanks,
-Jeremy
Old 09-29-2009 | 03:52 PM
Music City Scions
Yeah I was talking with my boy, and figured you needed a fuel setup with one in tank. But 1000cc just for 450-500? Hmm...I know PTuning has the 900 ones, probably just go with those.
