Turbonetics Scion Tc Turbo Kit
Basically, i have a great deal on a used Turbonetics kit, and i would like to see who is running the kit, and if the kit can be upgraded to make more power. I also have a newer model scion with diff MAF sensor, and i just got of the phone with Treadstone, they said they just came out with the newer 3" intake MAF pipe to adapt to the 07+ Scions and are using the AEM FIC. Feel free to post your dyno installation pics and any experiences you had with the Turbonetics kit....
you really like getting threads locked dont you...at least this one isnt too bad...
so you are getting an 05-06 kit and you have an 07+? If treadstone has an 07 maf pipe i would try to get that or else you can get a maf adapter from randode.
AEM fi/c is arguably the best piggyback for the tC, i am running it on my TT simple kit and it runs almost like stock.
How much power are you looking to make? the t netics kit will take you to 300whp....any more than that and you run the risk of breaking your internals.
search!! jesus christ 05-06 is the same motor as the 07 and up. only difference is the maf sensor. now dont post thread thats been discussed a million times. just use the search feature.you would be surprise what you find
PWNED BY MARCELO but in all seriousness SEARCH!
It's a good kit. I have an 05 u'll probably have an issue with getting the downpipe bracket to bolt on...just leave it off if it doesn't start to thread right away. I ended up having to retap a manifold stud because I tried to make it work..rangerryder had an 06+ and used his stock intake. Get a good tune and it will be a great kit. Tuning is everything.
I'm running this kit on my 2010. I used a Randode MAF adapter then eventually fabbed a blow through set up which I recommend if you're willing to spend some additional money. Definitely search any and all other threads about this kit so you know what you're getting into. If the dump tube has the flex tube then it's the V1 and will tend to crack. The solely oil cooled E50 turbos tended to blow their seals prematurely, so hopefully the one available to you is water/oil cooled since they have proven to last longer. As car_ram_rod said, the bracket on the dp may not align correctly (just a heads up). The E50's are generally smaller than most turbo's that come in other companies' kits; they spool fast, are fun, and will most likely be able to get you to your power goal if it is < 300. The FIC is pretty good considering how inexpensive you can get one for, but make sure you get a good tune! Good luck!
That's odd that Treadstone is replacing the oem 07+ TC's 2.5" MAF tube with 3". That should make for some interesting tuning issues...
The piping to the throttle body is 2.5" for the Turbonetics kit which is where I relocated the MAF. I finished my blow through set up and MAF load (g/s) between the scan tool and APR X1 are spot on now! Better said transient throttle response, more accurate IAT reading, hassle free atmospheric dump, elimination of rich decel occurrence, and better accuracy tuning off of the MAF are all great reasons to go blow through!
The t-netics kit itself is an awesome kit. Only thing I ran into on the v2 series was the one bolt for the downpipe to block not lining up. Otherwise its just a good tune and you will be right around 300hp.
i have the treadstone pipe and an 05 turbonetics kit, i own a 2010 tc and im geting 301 hp and 2965 torque, use aem or emange though. i love my kit, i upgraded to ball bearing garrett. i need a new downpipe for that kit, if you know where i can get one let me know.
cessblood
09-15-2015 06:50 AM
Xaphoon
01-17-2015 02:12 AM
ScionLife Editor
11-25-2014 03:00 PM
