turbonetics turbo option
Anyone know a good replacement for the turbo on the turbonetics kit 06'? Ive had problems with the turbo and my warranty is up. Im looking for something more reliable and maybe better quality. And whats the exact size on that, T3/T4 E-50 trim......? Maybe something with a similiar sized turbine. If you know any good replacements for it, let me know. Thanks
I think I have the same problem. I can hear oil dripping into the heat blanket on the turbo and smell burning oil while driving.
Paul
Given that the unichip is hard to get retuned for a bigger turbo, how much would a good replacement turbo that's about the same size cost?
Paul
Paul
Paul
Range anywhere from $775-1500 depending on if it's BB or not etc...
So I decided to go with a Street Heat Innovative turbo, 50 trim .48 stage 3 for my turbonetics kit but there is a problem....... I got the turbo today from fedex and I realize the entire orientation of the turbine is about 90 deg off. The oil inlet and drain flange are horizontal when it would be mounted to the header and the boost outlet tube is like pointing up towards the radiator. Im guessing I cant make this work myself w/o having to send it back to dezod. What do you guys think?
Team No Limitz
Did you try clocking the turbo yet? You can change the orientation of the turbo by clocking(realining the way the compressor and exhaust housing mate to eachother) it and this will probly fix your fitment issues
Just incase you dont know how to clock the turbo, Loosen the bolts in the area that I circled in red. Im only posting this because I just learned how when I installed my turbo kit.
Enjoy my paint skillz!
Team No Limitz
well either way I bet thats his issue right now and he doesnt hafta buy a new turbo which would be good for him
Well alright. I guess this isnt as bad as i thought it would be. I wasnt aware it was as easy as just loosening and turning the housing. I think I can manage doing that. This wont screw up the balancing or anything like that? You guys have any pointers other than just loosening and rotating? Or is it really just that easy?
Originally Posted by kirk212
Well after a new Innovative turbo, new Fidanza flywheel, and ACT clutch.... the numbers dont lie. LOOK BELOW
I went with the GT3076R, very nice turbo , only need minor mods to install it into the Turbonetics kit.
- add coolant lines
- weld on 90 degree elbow to outlet of compressor or 90 degree silicone elbow
- downpipe bracket connecting to engine block needs to be modified
- relocate boost line port (the one that connects to the WG) the GT3076R does not have a port on the compressor outlet so I connected it to the same place as the boost gauge.
- add coolant lines
